So I brought this up about half a year ago and there seems to be a new issue with Pitool only allowing 2 dongles to be plugged in at once. You need 3 for full body tracking in VR. Old workaround doesn’t work anymore either. Can only pair “2” controllers lol. Won’t even allow me to pair a single vive tracker anymore.
I had the same problem. Apparently windows causes the issue when it updates. I fixed it by making steamvr forget all the usb devices. Using a tool to delete the trackers from windows (it’s up on some steam link) and reinstalling Pitool.
This is the tool:
Here the explanation to remove usb devices from steam:
As a last resort for headset detection issues, you can reset your SteamVR USB devices.
- Unplug all Link Box cables from your PC.
- From your host computer, go to SteamVR > Settings > Developer. Make sure the Developer Settings checkbox is checked.
- Click on Remove all SteamVR USB Devices. Make sure the link box’s USB cable is not plugged in and click Yes.
- Once this is complete, quit SteamVR, plug your link box in (USB, HDMI, Power), and re-launch SteamVR.
Then just reinstall Pitool.
Idk if all the steps are necessary but doing that fixed it for me.
