I swapped the LCD (miniled or whatever they call it) optical engine for the microoled one in my Crystal Super (with Pimax Play 2.03 used for bnoth engines), and immediately noticed that the eye distance was way too narrow. I adjusted it from 62mm I had on miniled to 74mm on oled, and it still seems narrower. It’s not just narrower field of view - for example, when I look extreme left, my left eye gets to the edge of its lens before the right eye does, which usually means eye distance is too narrow. I can probably max out the eye distance setting in pimax play and be happy with it but I’m wondering if there is a better solution.
I did not do Pimax play reinstall or settings reset when swapping the engines - should I?
