Oct 23, 2021
Added some linked words to forum. The following words now link to there appropiate sites.
Amd
Asrock
Asus
Evga
Gigabyte
Htc
Intel
Msi
Nvidia
Oculus
Pimax
Pitool
Simracingstudio
Steam
Studioform
Ultraleap
Varjo
Xfx
Zotac
If you have suggestions for other additions please feel free to create a topic with word and link.
Okay folks OpenMR you may have experienced a couple of Downtime periods today. This was due to performing some much needed Upgrades.
New Features & Old returned:
- Whos Online: You can see a Bar with Avatars of who is online. Iirc you will also see a glow on a post if the Author is online.
- Characters Required: Will countdown Chars Required in Post.
- Docs: Found in Left Menu. Is a quick search for guides and later will add a new Community Help Category(will use Solved)
- Solved: Once a Community Help Category is created and enabled will be a place to ask questions and Op can mark Topic Solved with posted solution.
- BBcode: Expanded BBcode options for posting. Some also available in Gear in composer(post menu).
- National Flags: set in your profile and your Flag or National flag of your choice will display beside your name in Posts.
- Cake Day: On your Anniversary of joining here like Reddit will show a piece of cake by your name. Optionally you can put your Dob in your profile(optional). Regarding DoB recently it has been recommended not to have this info fully accurate; so either make yourself older or a bit younger or sinply a day or 2 off actual bday.
- Discourse Reactions: Beyond likes; not enabled yet. Will replace Likes with optional. Thinking keep it Simple "
" maybe 1 or 2 more. May remove retort or change up/restrict as these would allow extra reactions. As this one will only allow 1 reaction. However intend to keep it clean.
- Post Badges: is now user configurable in your preferences upto 3 badges.
- Saved Searches: Check your user preferences as you can configure this to send iirc a digest of new topics with keywords your interested.
- Follow: Does a particular user(youtuber) often post topics or things of interest? You can now follow a member to get notified of new posts, replies(configurable). Click on there profile and follow.
Atm the Hamburger menu is a mess as a component to restrict which categories are shown there is broken.
- Fixed Dropdown menu(Hamburger). Categories are no longer a huge mess. Just shows Parent Categories now.
- Had to remove pimax lnk as it was turning @pimax(members) names in part to links in mentions.
Now that I have some fixes in place can work on other improvements. Will see about adding Tobii to linked words when I get moment.
