this really sounds like vision issue or nervous pathology.
I have 5k+ & quest as well, quest is super sharp, easy to focus with huge sweetspot, no double vision, no chromatic abberation at all. Pimax has issues with stereo overlap as already was mentioned but it’s solvable but if you even can’t see clear with 1 eye moving & tilting headset around without face cushion then this is the first case since 2016 (when I started interesting in VR) I hear about.
Sorry probably you already mentioned but do you have that drunk feeling when you try to focus with 1 eye?
I guess your headset is ok. The best case I can think of is visit to doctor.
Weird. That’s not how I would describe my Quest. I use just as much time finding the sweet spot on the Quest as I do on my 5K+.
Both take seconds but the point is the Quest is no different, to me, than the Vive or the Pimax regarding the sweet spot.
Mostly is has to do with getting the IPD right and the vertical placement (on both). Placing the headset high enough (they’re not supposed to rest on the nose as some think) is generally the issue, for me…
Interestening, the first flag for me is that you seem to think the quest as horrible SDE, which is strange because its vertical resolution is like 1600
which for most people the sde is almost non existent. even though its pentile oled
the 8x+ has an rgb led at 2160 so there’s no easy it should be worse.
Remember to also tilt the HMD up and down as well as left right up down.
I had to tilt the HMD up from bottom to get it to sit right.
Dose your HMD have the comfort kit fitted ?
Ive tried it without the kit too. It’s the same. I found out something this morning. If I hold the Headset 10 cm in front of my eyes and look through the lense, the image look sharp.
That is very strange indeed. Suggests the optics may indeed be out of alignment. VR headsets are supposed to be collimated to infinite focus, much like an aircraft HUD.
If possible, you should take your HMD to someone with experience in VR.
well maybe Im not getting the sweetspot term right, will try to clarify what I meant:
E.g. I have a vive pro & in the middle it looks sharp, but if you move your eyes aside then all a bit smeared & some chromatic abberation can be spotted (it’s the case with vive pro only though), on quest if I look aside the whole image is sharp, sure if I will move my HMD far enough (0.5+ cm) then it will be out of focus, but not as bad as on other HMDs, e.g. on my pimax 5k+ I really need to do it precisely, while IPD setting has some freedom on Quest (Im 67). On pimax if I spread lenses a bit further from each other at some point I can see the image sharp on the side & even in the middle, but stereo overlap in middle is not usable. However when I configure overlap precisely in the middle I can not clearly see the image from I guess about 100-110 FOV (same as on common headsets). Also in terms of sweetspot index & rift S are good ones, Quest is a bit worse I guess but still really good IMO.
I guess if you close one eye & try to move different headsets around the clearest point you will notice that Quest has better clarity, probably you can also experience IPD issue though when one of the eyes is blurried a bit
IMO oculus has the best lenses in the game right now, index lenses maybe tied. May be an unpopular opinion but the image is just super uniform on the current oculus hmds, you have to try to get any artifacts. For the record I think Pimax lenses are awesome, but yeah its a way harder to wear the hmd, and theres some definite chromatic abberation among other issues. Canting makes these even more weird feeling…
As others have said if you can’t get the quest feeling right I’d check your eyes tbh. My IPD is 62, and 59-65 are acceptable on the quest.
You do realize the optical distance should not change if the VR display is collimated? A pixel in the headset should appear to be roughly as far away as distant stars in the night sky.
I’d say though old both Pimax 4k(p1 series) and Sony PSVR has best lenses as they used aspherical lenses vs Fresnel flavors. No rings to create undesired effects.
