Interesting design choice. Add a bit bigger circle and you could have a carrying handle.
Though as we can see doesn’t likely have furry pets.
If you are strong enough, once it’s obsolete you could throw it like a frisbee.
At people you don’t like.
Less compact than it could have been, unprotected components, could probably have fitted a more expandable motherboard at that size, no watercooling of the GPU, heavy air-cooled GPU heatsink still attached, and indeed no carrying handle.
Also, the ‘foot’ seems unnecessarily complicated, and the pump could probably be more capable.
Nifty, but doesn’t seem very practical.
Definitely like the wall cases just a glam case. Kind of like rgb lighting.
At least a fancy case doesn’t foul up VR driver software the way RGB lighting software does.
