My super keeps going into standby
I have tested in MSFS 2024 and VR chatg and my headset and audio cuts out every so often and when I wave my hand in front of the cameras it comes back on. I looked and cannot find any settings related to sleep or standby. Should I create a ticket or am I overlooking a setting?
Check the headset time out settings
I did. Thats what it is. I found a post that suggest to put tape over sensor. I’m not doing that. Hopefully they will add more time to the timeout. Very annoying.
Thanks for the reply.
