I’ve installed the Pimax 4K VR and Software V 1.1.92. I can see a second Screen in my system with resolution 1920x1080 but the PiMax software says the HMD is not connected.
Im my attached Picture you can see the second Screen and the Resolution and the PiMax Software.
The trick was to start the whole system wirst without the PiMax and the connect it. (unplug and re-connect also works)
But you can see it’s not full screen.
And the resolution still says 1920x1080, not 4K.
Furthermore, If I switch to the games folder nothing is displayed. I can’t select a game.
So, how can I use the PiMax?
Furthermore, I have my own 3D-360 Videos. How can I open those ? ( and also3D-360 pictures?)
Futthermore, I’ve closed the PiMax Play window. Now I can’t open it anymore. What can I do?
regards
Rolf-Dieter.
