I have a Qubic System motion platform, and it provides OpenXR motion compensation. It worked very well with Quest 3; however, with Pimax Crystal Super, it often loses tracking, and compensation is broken. Does anybody have experience with this? Does Pimax Play 2.0 improve tracking?
Hi,
I use Pimax Crystal Super (50PPD) with a custom-built 6DOF motion rig. It works perfectly with OpenXR Motion Compensation. However, I use a very old (like 3 years old) version of OXRMC.
I had issues with the inside-outside tracking with my Crystal Light too. I bought a used Valve Index bundle with two lighthouses and controller. And then You need a lighthouse panel from pimax. Sure, this much money. If you checked YouTube, you found many people with this issue and many of them switched to Lighthouse tracking.
Be careful, the original controller is not compatible.
Same with 6Dof. I think SLAM Tracking is not good for motion Systems.
