Maximum IPD for Crystal (real people playing long sessions)
After trying and sending back Varjo Aero, I want to ask who has big IPD and successfully use Crystal for longer playing sessions? Please somebody who has ipd 73+ mm write about your experience…
I have IPD about 74-75mm, and I use 8kx; my IPD slider there goes up to 70mm (written in HMD), and then it moves a litte more. I can use my 8kx several hours without eye problems.
Just for record, Aero has IPD up to 71mm, and they said people with 73mm can use it. I really do not believe that. I was crosseyed (a lot) since start, and also color shift was much stronger because of me looking outside of sweet spots. Pitty, as I mostly like it (except no audio, mic and hmd was hard to put on/off).
@SmallBaguette may able to provide feedback on this! His IPD is around 72mm, if not mistaken.
Edit: This is definitely my mistake. Lol.
Ah my IPD is a pretty average 62mm so I can’t provide any insight here.
I do know a couple of high IPD users, I think about 72mm so I will ask them.
Fwiw, aspheric lenses are a lot more forgiving with IPD than fresnel and on the Crystal I don’t notice any signiticant change in image quality with +/- 2mm IPD adjustment but that might not translate to the extreme higher end. If I hear back from anyone then I’ll let you know. Might be best to post on the Pimax reddit also, or the discord, they are a lot more active.
My IPD is 70mm not quite as big as yours but I have no issues.
Pimax is also, releasing wide FOV lenses soon, which actually have more separated Binocular Overlap so that may actually help you as well.
Mine is 69.5 and i’ve had no issue with the Aero, 8KX, or any of the 10 headsets i’ve owned in 9 years of using vr. An interesting thing i’ve noted with my Quest 3 is that the ipd slider i can basically set at any value and the display doesn’t change much if at all, i know if i did this on other hmd’s i’d be going cross eyed. Thankfully it is a clear non cross eyed image i’m experiencing at any ipd on the Q3.
My first VR HMD was oculus CV1. I had to put some rubber eraser between the lenses parts to have them separate enough for using.
Then I had 5kx, and 8kx - in booth I was pulling that dial for IPD to maximum and beyond :slight_smile: they didn’t broke, and I was suddisfied with ipd adjusment.
Beside that I tried 3 other HMDs, all 3 were not suitable for me;
Playstation vr version 1, quest 2 and varjo aero.
I do thik that my IPD is about 74-75mm, even if my measurement in glases store was 77.5mm on looking to infinity.
With 77.5 I wouldn’t be able to use any HMD
I tried meta quest 3; IPD was too small for me, headstrap was nightmare, but I also had problems with facepad; it was pressing my left and right side a lot. It is designed for small IPD and small head too.
UPDATE: I bought Crystal, and I can use it with my IPD. Didn´t play long sessions yet, but it works for me :smiley: Even eyetracking works!
In Crystal is written dial up to 72mm, and that is my setting. As lences are pretty good, with bigger sweetspot, I have no problems.
PS: For 12k please pimax make that dial up to 75mm to cover all my relatives too :crazy_face:
