Hey team
Would appreciate if any MAS owners could quickly check this measurement for us
Just the height of the blue section on the back, not including the black foam support underneath Cheers!
Hey team
I am reading approx 51mm/2 Inches on my Tape measure.
Thanks Helio!
Just to confirm that’s the blue section only. Not including the cable clip on the left or the pad support underneath? Cheers
Your quite welcome!
Only the blue. No cable clip. My measurement of the blue plastic was just right of the adjustment knob. Looking at the rear.
Awesome thanks! lucky your on metric
Well tbh I myself use more imperial save for the speedometer.
