Enopho had said that pitool 1.0.1.132 worked best on pimax 4k, but all the old installers are gone, anyone have a link? On latest pitool I get some screen tearing, and I don’t get this but instead more ghosting than normal on piplay 2.0.7.54. I would like a link to pitool 1.0.1.132. Thanks!
On another note, the up and down buttons on my pimax4k do nothing. XD
Follow this link
The up and down buttons should control volume.
Yeah they haven’t done anything ever. The osd works though, when I change volume with keyboard.
This might be something that got broken when they went from piplay to pitool. Did this work at one point before? The headphones work?
@TheDeaX @Enopho may know more.
@Alex.liu can you look into this? 4k Vol up and down not working.
I never plugged in the headphones, maybe that’s why? The button’s never worked, but thought I may as well add to this to finally find out why. Thanks for the downloads.
Yes indeed without the headphones plugged in the volume buttons don’t have anything to control. If you don’t have the p4k headphones both ports support stereo.
If you do have the p4k headphones I highly reccommend checking them out.
