I’m looking for a simple headband or strap for My 8K+ so I can adjust the settings, lighthouses, controllers, and spend some time with it while I wait to order my MAS. Any links or ideas. Very hard to do with one hand holding up my +.
Where did you buy your 8k+? Didn’t it come with a cloth strap?
I will look in my box again. It came as a bundle from Pimax. From the store page it is marked no MAS.
So maybe I could use some type of velcro from my hardware store if I find someing thin to fit thru the loops? or an old bedsheet?
As Trevor said it ‘should’ have a simple headband in the box
