It was announced in Reddit 3 days ago, but I don’t see anything here.
It’s a little pricy at $199, but at least it’s available now. Just want to spread the great news.
As far as I can tell from the website, it can now be ordered, but the page says “Preorder” so unless someone can confirm that they’ve actually ordered and received one, I’m not so sure it is actually “available” yet.
I ordered mine directly when it came out, I will tell here if you want to, when i got mine
Yes, let me know. The biggest thing I will want to know is whether it still has the same limitations as the one for the OG (microstutter and obscuration issues). I could never get mine to work well enough to use regularly, even after working with support and trying a second one, so while I’m anxious to try this on my Super, I’m dubious since I’m not sure whether this is just basically the same faceplate rewired for the Super.
I will check it and tell you
I ordered one right away let’s hope we don’t have to wait to long to receive it can’t wait to use my index controllers again!!
There will be an update for the Lighthouse faceplate coming up.
Uhh i can´t wait for it, even more while I will need to use the Pogo Pins for my Headset, since the lower USB-C is used by my self made Facial Tracker ![]()
Just filmed the footage for the Lighthouse faceplate, and the editing is in progress.
I just saw the short at Youtube that looks nice, but i will definitely need the adapter for my Headset, since lower USB-C is used for Facial Tracking and Upper USB-C for Audio while i switched to the HTC DAS Strap and want to use 24bit audio ![]()
If that’s the case, please contact support to request the Pogo Pin.
As mentioned before, we can assist with the installation, or you may install it on your own.
when its still is just plugin it in then i am good, do I need to contact the Support via Ticket or Via Chat?
Via ticket please.
alright thanks
So where is it? We are in march and there is no update
Here buddy: Progress Update March 13th - #3
Hello, when will the Faceplate finally be available or shipped?
Based on the update, the estimated delivery is in early April.
We have also shipped units to some users this month for testing purposes.
another completely absurd statement that the devices would be delivered at the end of january, even though they are only now being sent out for testing purposes.
at least Pimax is staying true to itself. ![]()
