Leap Motion Sensor as camera
Hi guys,
is there any chance that Pimax can integrate something like that?
Here is example:
and API basics:
https://developer-archive.leapmotion.com/documentation/csharp/devguide/Leap_Images.html
It would be great if we could use this cameras for example for chaperone.
In theoey I don’t see why not. Though may need to figure out a Camera modul maybe pluged into a usb-c powered hub(ideal of more than 2 modules) plugged into the 2nd usb-c port.
The pimax hand modul is leap.
I was thinking about camera like that but leap could be enough for such task as chaprerone and we wont need additional attachment :slight_smile:
The Leap uses infrared so it needs to light its torch light upon things to make it visible. It basically works like a night vision goggle
That should be already working.
I’d like to see a 3d camera like the zen mini.
Indeed. Also checkout Reality blender looks neat for sim games & free in Steam!
It depends if leap is visible as camera for the system i guess.
It IS a camera. It just has an IR filter so it blocks normal light and only sees infrared
