Why are the technical data so poor on Vr headsets.
If you have luck the manufactorer specify fov, resolution and display type.
I have not seen any specification of the lenses. How bad are they outside the sweetspot, distorsion resolution etc. How big is the sweetspot where you can disolve the pixels.
What is the resolution in vr, pixel density per degree.
How should I as an potentiall buyer be able to compare different headset with this lack of data.
Worst example is StarVr that actually avoid to specify the resolution just number of pixels that also include sub pixels.
With Lenses your apt to get basic info. Fresnel, Aspherical. But nothing like you would from professional cameras.
As for sweet spots this usually comes from independent reviews. Look at heafsets like psvr generally don’t post the lenses sweet spot with only having soft ipd.
