KDMAS Pimax 8KX Feedback
I bought the KDMAS because I have been waiting for the end product from Pimax for many months. I’m still waiting for the DMAS which I ordered a long time ago!
As a transition, I ordered the KDMAS.
The workmanship is good.
What I now notice after a few different games is that these Pimax KDMAS heads generally sound a little deeper than the Vive headphones.
Not bad, but different.
In some games I miss a little more sound, medium sound. The vive sound a little clearer there.
However, the bass is missing from vive.
I also have a vive deluxe audio strap and can compare it.
vive deluxe audio strap VS Pimax KDMAS
vive:
  • good overall sound
  • good midrange
  • clear sound
  • very little bass
KDMAS:
  • a little deep sound
  • good deep bass
  • Midrange not so clear or too little
  • Really great for music games It is not noticeable.
Still, I think the Pimax KDMAS is quite ok.
So for 59 euros ($ 49) … you can buy it, yes!
A thousand times better than the SMAS.
Important!
The headphones are not close enough to your ears!
You have to print the adapter for the KDMAS at thingiverse.
Go to the thingiverse homepage and search for Pimax KDMAS. There you will find an adapter for the KDMAS.
Download the STL file and print it with a 3D printer. That works very well. The sound gets a little better with it.
Another tip:
Download the Equalizer apo program!
Use these equalizer apo settings:
Graphic equalizer with 13 bands.
And add these settings:
GraphicEQ: 25 8.4; 40 6.5; 63 4.7; 100 3.1; 160 0.1; 250 -2.8; 400 -0.7; 630 2.3; 1000 5.5; 1600 6.8; 2500 9.2; 4000 5.2; 6300 0; 10,000 0; 16000 0
Then download the program Boom3D and activate “3D Surround” and set it to “Game”
Only then will the sound sound really good. The missing midrange is also there!
20210723_143502|666x500
Not to disdain the KDMAS or anything, but can’t we just 3D print a mount for the Index Headphones ?
Also, did you try to increase the BASS of the DAS in Windows sound enhancements ? That solved the lack of bass for me.
Yes of course
as it is now, it’s best.
with the printing parts it is better.
just like index makes no sense. The sound is too weak for that.
here are the first equalizer apo settings.
Or maybe use the HP G2 speakers ?
KDMAS is quite good indeed
Its indeed quite good… i use the program boom 3d with it and its even better…
Hard to say on that as there is an Auto Impedance adjustment. You need to connect the sound to hmd while powered off. On power up it will adjust output.
HP G2 is said to use same drivers as Index.
That bring said one might be able to use the smas disassembled module as a base for mods using the MAS audio cables.
yes Boom 3D have now also tested.
it is very good indeed.
the best combination is both together.
So my equalizer setting above with the software and together with Boom 3D.
the two together make it really very good!
the sound becomes clearer.
