HTC is back! Vive pro 2 with 2.5k * 2.5k per eye @ 120 hz
I’m also still somewhat skeptical. Luckily we don’t have to wait very long!
i realy hope it matches the color and sharpness off the hp reverb g2 and the minimal glare as the G2…Then i am very happy
With double fresnels, I have a hard time imagining we can expect anything significantly better than the Valve Index situation, glare-wise, unfortunately. Here’s hoping to be pleasantly surprised.
Yes i am a little afraid off that…
Doesn’t Varjo use something similar to stacked lenses?
As much as a love my 8kX its a love hate relationship with the (tried for 6 months to tune) eyestrain so im willing to go from normal to small FOV to get a plug and play hmd at this point. Deffo gonna give this a try
The resolution on the 8kX is spread over a larger FOV. This Headset should be considerable/ noticeably sharper than the 8kX but will have to wait and see
The vive pro 2 will be a good allrounder , hopefully it will satisfy enough and make me not to buy the varjo lol .
I wish htc would have aspherical lenses though … this time we cant simply swap out the lenses from a cosmos xD
Not fresnels, though, as far as I know.
I have pre-ordered it too.
But the refresh beyond 90 Hz is not attracting me that much: the burden on the GPU will be big enough with the VP2‘s resolution, I will not be seeking to increase that burden even further.
One of the big promises of this headset is the option to go wireless. But will wireless be great too ? Or will the resolution be seriously reduced due to the wireless bandwidth capacity restrictions ? If this restriction brings it back to Vive Pro levels (save for SDE), then it will end up beiing a tough choice to go wireless. I don‘t fancy to go back and forth on the wireless option, because it‘s a bit of a hassle, I believe. So I would want to use it either wireless or not, and stick to it.
Part of the greatness of the VP2 will depend on the FoV - if the FoV is not increased over the G2 level, I doubt that I will notice the greater resolution on that FoV: so why even get the VP2? It might be more comfortable (the G2 is quite tight), wireless option and it gives us native Lighthouse, and… err, that‘s pretty much it then. So to really shine it needs a greater FoV than the G2.
Bottom-line for me is that the VP2’s greater load on the GPU needs to result in true visual improvements for me, and I doubt that would be the case with the G2 FoV. Otherwise in the worst case it actually looks worse than the G2 because you have to dial down the settings in game to render the greater resolution. This is why I don‘t anticipate that I will use the 120 Hz option (other than perhaps for games like Eleven).
Looks like the wireless supports 1632 x 1632 per eye ( coming soon ) this is definitely going to be the best possible wireless visuals available on the market , until they bring out wireless 2pro+
I’ll be really interested in hearing the first hand impressions of what the FOV feels like compared to the 8KX’s small and normal FOV settings. I don’t have any issues with distortions on my 8KX so I really love the normal FOV. I have played with small a few times and it isn’t horrible either although I mostly just stick with normal. If VP2’s 120 is really the same (or better) than 8KX’s small with a noticeable increase in resolution and clarity then that would definitely give me something to think about.
Well, there is the quality from an optical standpoint; If the Pro2 gives a larger area in focus than the G2, then that is something. The older Vives, which never enjoyed a lens upgrade, were not too impressive on that front - I guess we’ll se what the new lenses do.
If nothing else, one might speculate that it will not have the “spare” stretch of “unused” lens out to the sides, that the Pimaxes do when you run them with restricted FOV, in which case it should exhibit the old aperture occlusion issue, where the FOV to the right shrinks slightly from your turning your eyeball to look to the right, which consequently moves your pupil closer to the right edge of the lens…
The Pro2 does have Relief controls, but I doubt it will have one degree more FOV on a non-Asian head than an old Vive with no foam.
My favorite part is the line “until I try it for myself i just can’t recommend this headset”
I should frackin hope not. As for the “Hard Pass” title, that’s a lot more of a conclusion than the “until” condition he applies in the vid. Rather unfair until you actually road test it.
It is hilarious that some of these guys put themselves up as “everything you want to know about VR” authorities and then do these speculation vids. Somebody should tell this guy that until you know everything you can’t speak to everything and a not fully informed opinion is just that.
Him rehashing of his Vive Pro issues is just more filler because he really has no substance. 10 min I won’t get back. :grinning:
Just for the record, I asked HTC support about the IPD range support in Vive Pro 2 and response was:
Kindly note that the IPD range of the VIVE Pro 2 is 56.95 to 71.78mm.
Go figure :smiley:
Now that is an ambitious degree of precision. :7
I was about to buy the Varjo, but coming from an 8KX I am seriously concerned about the FOV being such and issue, even if the clarity is far better.
I had the G2 for a couple of days and couldn’t get used to the FOV after running the 8KX.
So I’ll give this Pro 2 ago, not to compare against the Varjo, that’s never going to be even close I doubt, but as a tester HMD for the reduced FOV of the 8KX. They Pro2 will sell out for sure, so I won’t lose any money for sure
I did own the original Pro, and that was a super comfortable HMD so I’m quite excited.
Let’s be honest, any new HMD, with such a short release date is exciting anyway, it’s given us all something to chat about, speculate about and even a few people have point blank refused to try it. I know how they feel as I refuse point blank to try spaghetti.
He’s buying the headset anyway for his viewers…so he’s not passing, lol. He seems to have level-headed reviews, just made a click-baity thumbnail
So labeling his vid “hard pass” is what then, just hypocrisy or an attempt to sensationalize his title for clicks? Certainly not level headed thinking in this one.
