HTC is back! Vive pro 2 with 2.5k * 2.5k per eye @ 120 hz
13th here (but in the US), still “Processing”
I wish I had at least pre-ordered from Amazon.ca. I didn’t find out the headset was on Amazon until it was too late.
Just the additional $600 from your bank account and not having to use parallel projections…but other than that…
Order from Amazon and cancel you other order.
I can’t anymore lol. Headset is out of stock on Amazon and my debit card has already been charged for the Vive.com order.
If you are running 3 screen, I’d take you are have a 3090 since it has the 24GM video memory? I always keep only one monitor when viewing VR. Try avoid resources taken when you want to power a high res hmd
What GPU are you using?
HTC is not doing well. They had to layoff personal after The HTC Cosmos Flopped
I think you get a $50 dollar discount, but you won’t if you do an order now from B&H
It’s a bug and I have a 3090
You have exceeded max gpu screen limit. Do not use more than 3 screens. I’ve always had triples and vr and it’s the first hmd to ever have this issue.
Max gpu limit is to my knowledge 4 or 5 without checking it
OK, I personally try minimize any resource that could affect performance. Th 3090 should do OK with 3 monitors since it has plenty video ram. Older VR headset didn’t have the resolution of the 8kX, G2 and V2. It is wise to be mindful of what you have connected to your rig when wanting max performance.
I will skip the Vive 2 for now Where I am at it cost $900. No way I am paying that
Even with the discount, it would have been cheaper to go with B&H. The Vive Pro 2 is priced in Canadian dollars the equivalent of $900 USD. Also my coupon kept failing so when I cancelled my original order to retry the coupon I lost $52 USD in Paypal conversion fees which HTC refused to compensate me for.
That’s the Vive pro 2 with 250%SS and extreme settings ( maxed out )
This is the furthest point in steam VR home
As you can see you can’t read the text at all . That’s also the case in the HDMI itself!
That’s 4572x4572 per eye !
Now that’s the G2 with 4564x4564 per eye (208%ss)
I can read the text perfectly fine from the farthest point with the G2 !
It’s a HUGE difference .
Have you tried increasing the SS to 400%?
This might sound way too high, but for some reason HTC decided to set the 100% value very low, so 300% or 400% or so is actually a reasonable value to use for non GPU intensive games like beat saber, paired with a very high end GPU.
250% is already a deal breaker because you can’t play Alyx with 120fps without getting reprojection on a 3000$ gpu ( msi gaming Trio X rtx 3090 overclocked) . I was getting reprojection a bit on 150% ! So there is absolutely no point in increasing the super sampling over 200% on the Vive pro 2 if you wanna play with those unbelievable epic fluidness 120hz :heart_eyes::drooling_face:
The resolution is really really meh on the Vive pro 2 :confused::expressionless::-1:and the glare is insane as you can see compared to G2
Well it doesn’t look like that in the headset. You want to retake the photos maybe with the camera as close to the pro 2 lenz as you have it to the G2?
Tried my best with my one plus 8 pro camera (lol)
The point is you CANT read the text from the farthest point of the steam VR home area whereas you can with the G2 + no godrays
try the settings on the 90hz,the highest setting,it does look better for me somehow…
