Hey mate, you bought the 8k-X again? Haha, nice!
My take on getting the best image quality
- Forget about trying to get the 8k-X close to your IPD. That’s only something relevant with normal headsets, not with Pimax headsets
What you see is NOT what you get with Pimax, so just forget that. Panels are most likely misplaced and the whole Pimax IPD system just makes no sense. So it’s really irrelevant what your IPD is, you should not even try to match that with Pimax, it’s useless. - Your first objective should be to maximize clear vision over your FoV. That’s what you do with the hardware slider. Just increase/decrease it and notice what it does to the clear part of your FoV. Alternate between looking through your left, right eye, and both eyes, until you get a good sense what the best position is for maximum clearness. The goal is to position the lenses so that they’re in the middle of your irises, so the fuzzy part at the edges should be equally far left/right from each iris. If you play long enough with this you should get a good idea where that is.
- Once you’ve found that, then the 2nd objective is to minimize eye strain and maximize 3d effect, which seem two sides of the same coin (you’ll achieve both at the same time). This is done with the software settings. I see 2 ways to do that which both can work complementary:
3A) In the real world, alternate looking through your right and left eye. Look at an object several meters away and notice how this object ‘jumps’ left/right but potentially also up/down when looking through your diffferent eyes. It’s my theory that you need to simulate this in VR too. Now do the same in VR, look at an object that’s the same distance as the object that you were looking at in the real world and adjust the software sliders. You’ll see that the sliders increase/decrease the different position when looking through your left or right eye so make it so the distance is simulated in VR
3B) a different way is to, in VR, focus on an object in the far distance and then look at a straight line and see what happens when you change the settings. In your ‘double vision’ you will see a 2nd line that gets closer/further to the first line. You need to line them up
Now when you’ve found a good setting, you might need to finetune it: Go play a while and see if you get eyestrain. It should at least be better than before, so more time playing without eye strain. What I did next is I changed one of the settings slightly and then the next day played again and see if this improved my playing time without eye strain. I repeated this process over a few days and then ended up with a setting that seems to give me no eye strain at all anymore
