Whats the best way to keep the foam of the comfort Kit clean? Can it be fully washed or should it be rinsed only or is it best to use a disinfectant wipe? And can I use some cleaning soap?
Hello,
We are not suggested you fully washed the foam, you can rinse the foam or use a cleansing wipe.
And please kindly prevent it to expose under the sunlight for drying session.
Sincerely.
Many thanks for the quick answer. Is there a cleaning guide specially for Pimax Headsets, like how to get the body dust free eg.? I found this general guide (which is very helpfull too), but maybe the Pimax material need special treatment: https://www.roadtovr.com/how-to-clean-your-vr-headset-oculus-vive-index-quest/
Wahsing mine now since 2 years with my shirts 30 degrees celsius, having no issues at all. Just don’t put it in the tumbler or wash it any hotter
2 Years… That would not be the Comfort Kit then, that would be the original foam from the original “Facial interface”
True, but I have the Comfort Kit too and it feels like the same material to me
I put mine in the freezer for a couple days, should be clean now
It is better to clean it some kind of dust cleaner and if you face any difficulty for finding the best dust cleaner so I suggest you visit at Home & Garden Coupons they offered the various collection of dust cleaner at a very reasonable amount.
