How do Pitools and the Pimax Experience work together
I’m a bit on the slow side I’m afraid; I don’t understand how pitools and the PE interact and work together. Why do we need Pitools?
I get confused because sometimes I’m able to configure the PE with steam and get 74fps on DCS, and other times I struggle to get 40FPS.
What should I be doing in Pitools and in the PE to optimize performance, and will we ever be able to just use the PE? That would go a long way toward making the Pimax HMD family user friendly enough to compete with the G2 and others. @SweViver… can you explain this is language a dummy like me can understand? I think we need some sort of manual for this. If there already is one… sorry!
Cheers
Finn
Pimax Experience uses an API (an interface) to connect to PiTool.
PiTool is still needed but You can set everything in Pimax Experience.
Thanks… I’m going pretty much leave pitools alone then and see how it goes. The PE is much more capable and easier to use.
I totally agree… :+1::slightly_smiling_face:
I only use PiTool for checking initial tracking status and for start/stopping PE.
