In anticipation of 8KX I enjoy the clarity of the Pimax 4K (Aukey).
If 8KX will have even higher definition image, then I will be just happy
what controllers are you using with your 4k?
I use a regular Xbox-compatible gamepad.
I use the nolo cv1 Controllers.
Huh! Aircar wont run for me. It keeps crashing.
In my case, AirCar always worked well.
Before that, I ran it on 8K, I did not notice any problems.
Perhaps the issue is in the system?
