What aps we can run to measure fps in opexr ? In the past, I used FPSVR but it only works with the Steam VR environment. I need it for LMU . In theory in this sim I see gpu/cpu measure tool to bind for button but is not working or I’m doing something wrong.
There is a PimaxPlay 1.41 special version compatable with OpenXR_Toolkit. And Toolkit has FPS counter. Btw. old quad views works too: Pimax Play v1.40.4 - #31 by PimaxQuorra
PS: Take care that OpenXR_Toolkit is not combatable with some XR games :\
I’m using Mr Mbuchia PimaxXr tool 0.4.4 as Pimax Client XR implementation is too slow . I’m using OpenXr Toolkit and dont see fps counter there. Can you paste screenshot and version?
I am not at home, but you have to enter Openxr toolkit screen in vr, on first tab enable fps in overlay (top, first or second line, default is “nothing”)
To measure FPS in LMU through OpenXR, the easiest way is to use the OVR Metrics Tool from the Meta Horizon Store — it works without SteamVR and shows FPS and CPU/GPU load. If you are playing via PC-Link, you can enable HUD in the Oculus Debug Tool. For deeper analysis, there is a RenderDoc, but for a simple FPS display, it is not suitable
