Flickering in game with 5K plus
Date: 27/12/2024
Issue Title: Flickering in game with 5K plus
Description:
Hello, I just installed my Pimax 5K Plus, and in game it’s unplayable, the image is flickering on both eyes, but the steam overlay is perfect. (See video 1) I tried “Blocks” google’s game and on the videos it’s the steam vr home. On the computer the game looks normal so it’s not a tracking problem.
This happens 90% of the time, sometimes it’s ok. When the problem happens, when I turns the head I see some black borders like there is a buggy screen in front of me. (See video 2)
Thanks for your help.
HMD Model: 5K Plus
First 3 Numbers Serial: 203
Pitool Version: 1.35.02.01
HMD Firmware: 2.1.255.269
System Info
  • Windows Version: Windows 11 24H2 build 26100.2605
  • CPU: Ryzen 7950X
  • RAM: 32GB
  • Motherboard: TUF GAMING B650-PLUS WIFI
  • GPU Model: GTX 1080TI
  • GPU Driver: 566.36
  • SteamVR Version: 2.88 / 2.94 beta
Attachments (Pics/Video etc..)
Looks like a failing cable. I would try reseating the cable into the headset, and also plug it into a different display port output on your GPU and then see if that improves it.
Yea, just got a new 5K+ as a replacement.
The firmware was outdated, and the latest is 273.
You would need to temp go to pitool Version V284 and it will tell you, you have a firmware upgrade(seen you’re outdated too on FW 269).
it will update and also give you the 144hz option too.
Then you can go back to piclient 1.35.
But yea, first try different ports or taking the cable out and putting it back in(reseating it)
It was SteamVR, rolling back to older version of steamvr fixes the problem
For some reason I have the 144Hz mode in Pimax Play.
I tried to install pitool from Pitool Download – Pimax VR-T but the headset id not detected.
But in my case steam vr is the issue, older steam vr version works fine. I hope an update will fix the issue.
pitool V270 is outdated.
and V284 was the last one, and the one with the latest FW for our headsets.
not sure why there is still the old one on that site, even the FW is 3 versions out of date.
and yea, i am using SteamVR 2.7.4(previous version) build and have no issues.
but yea, after going to that pitool, letting it update.
i deleted it and went back to picleint 1.35
here: Pitool 1.0.1.284v for the newest pitool at the time
