NOT based on final PiTool software - EXPECT IMPROVEMENTS.
- Full >1.5x Total SR achievable with the Pimax Vision 8kX and demanding VR apps, without dropping in-app quality config.
- Efficiency is better - equivalent visual quality to the Upscaled 8k+ requires fewer pixels (less load).
- Pimax Vision 8kX plausibly can be configured to provide better visual quality than 8k+/5k+ on any VR ready computer.
- Point of diminishing returns for visual quality on the Pimax Vision 8kX is closer to 1.5x vs 2.0x .
- Relative black levels are excellent, absolute black levels (ie. pitch black night flight) may improve with backlight control.
- Upscaled 8k+ can achieve much smoother and more realistic visual quality than 5k+, but is not clear as 8kX.
- VirtualDesktop and Overlays fare particularly better in the Pimax Vision 8kX, being sharp (especially any desktop app with built-in supersampling), rather than blurred (at best) in the 8k+.
All spreadsheets are in ā.odsā format, and may be opened with the Free Open Source Software, LibreOffice.
Only a few numbers are particularly important for end users to use - highlighted by magenta boxes.
Remember to check the tabs at the bottom of spreadsheets - multiple separate pages are used.
Each application has one or more spreadsheets, to accommodate different headsets, and āfastā profiles which may not require Smart Smoothing.
One spreadsheet at the root of the repository has fully tested parameter sets and load calculations for all major applications.
https://github.com/mirage335/extendedInterface/blob/master/app/DCS/_sequence/000-param-Pimax_5kp.ods
_
Complete parameters, for PiTool, SteamVR, NVIDIA Control Panel, and quality configuration for the apps themselves, are included on the spreadsheets. Nevertheless, some of the important parameters are enumerated here, for reference.
Pimax Vision 8kX max res/quality, āfastā, and Pimax 8k+/5k+ max res/quality parameter sets are provided. Notably, the Pimax 8k+/5k+ parameter sets produce just slightly lower quality results (when used with Upscaler/8k+) than the āfastā sets for Pimax Vision 8kX, but require far more rendered pixels.
Near double GPU load can be required to achieve best visual quality in the 8k+. Smart Smoothing can become essential in this case, where it would not be for the 8kX. Elite Dangerous was particularly notable for this behavior.
Upscaled ā8k+/5k+ā profile renders 1.89x more pixels than the ā8kXā āfastā profile for Elite Dangerous, the latter being a higher quality image. Arguably, some tradeoffs might bring that down to 1.36x or so, but at noticeable loss of quality below what even the 8k+ or 5k+ are capable of.
DCS World is crystal clear - no fuzziness or SDE at 1.5x Total SR. MSAA x2 can be enabled, preventing shimmering issues. Instrument flying is painless to the point the Hornet mechanical instruments are worth using at times. Smart Smoothing is necessitated by CPU spiking in most situations, so āfastā parameters are not really appropriate - it is worth pushing visual quality to max instead.
Elite Dangerous is comfortably razor sharp at 1.5x Total SR. Orbit lines barely have any āroughnessā to them at all, text is not fuzzy at all. Smart Smoothing is not necessary with āfastā parameters, so this is perfect for doing desktop work through overlays while standing by to help team members.
Both DCS World and Elite Dangerous are readable at 8k+/5k+ parameters. Instrument flying hours at a time would get a bit unfomfortable though, and desktop overlays are inevitably blurry with anything other than the 8kX. DCS World Hornet mechanical altimeter and AMPCD text (without map) is readable though a bit fuzzy and lower contrast. Elite Dangerous HUD and objects, are comfortable enough, though again the 8kX can avoid smart smoothing or achieve even sharper results.
Undoubtedly, many members of the DCS World and Elite Dangerous community, as well as some developers, have deeper knowledge of the impact of specific quality config settings. These spreadsheets document quality config settings found to be usable at carefully chosen resolutions.
Many days of retesting went into iteratively determining these optimized parameters for the Pimax Vision 8kX under a variety of relatively severe test cases.
_
Optimized 1.5x Total SR - DCS World - Pimax Vision 8kX
- 1.25x PiTool Render Quality
- 2700v (3314x2737) SteamVR Settings > Video > Custom Resolution
- 2700v (3314x2737) SteamVR Settings > Applications > [App] > Custom Resolution
- 1.2 DCS World Pixel Density
- High Textures, Traffic, 2x MSAA, MAX Treesā¦
5760x3240 Equivalent Resolution
Optimized 1.5x Total SR - Elite Dangerous - Pimax Vision 8kX
- 3207v (3823x3274) SteamVR Settings > Video > Custom Resolution
- 3207v (3823x3274) SteamVR Settings > Applications > [App] > Custom Resolution
- 1.25 Elite Dangerous HMD Quality
- 10/10 Model Draw Distance, High Texture, MLAAx4, High Environment, High Material, Ultra Terrain, Ultra Terrain LOD, MAX Terrain Work, Ultra Terrain Material
5699x3206 Equivalent Resolution
Optimized 1.0x Total SR - DCS World - Pimax Vision 8kX (fast)
- 2295v SteamVR Settings > Video > Custom Resolution
- 2295v SteamVR Settings > Applications > [App] > Custom Resolution
- 1.0 DCS World Pixel Density
4080x2295 Equivalent Resolution
Optimized 1.0x Total SR - Elite Dangerous - Pimax Vision 8kX (fast)
- 2700v SteamVR Settings > Video > Custom Resolution
- 2700v SteamVR Settings > Applications > [App] > Custom Resolution
- 1.00 Elite Dangerous HMD Quality
3840x2160 Equivalent Resolution
Optimized 2.3x Total SR - DCS World - Pimax Vision 8k+ (Upscaled), 5k+
- 1.75x PiTool Render Quality
- 2772v (3823x3274) SteamVR Settings > Video > Custom Resolution
- 2772v (3823x3274) SteamVR Settings > Applications > [App] > Custom Resolution
- 1.2 DCS World Pixel Density - EDIT: Confirmed, retested.
5912x3326 Equivalent Resolution
Optimized 2.0x Total SR - Elite Dangerous - Pimax Vision 8k+ (Upscaled), 5k+
- 1.50x PiTool Render Quality
- 2970v (3823x3274) SteamVR Settings > Video > Custom Resolution
- 2970v (3823x3274) SteamVR Settings > Applications > [App] > Custom Resolution
5280x2970 Equivalent Resolution
_
Future workā¦
- Other VR apps are expected to be much easier/quicker to optimize/test.
Much thanks toā¦
- Pimax for early access to a loaner Pimax Vision 8kX for testing, without which substantial improvements would not have been possible.
- DCS World community, specifically āLukas S. / Woltaā for āDCS: VR Optimization Guideā which drew needed attention to MSAA settings.
