Have you set the maxRecommendedResolution in SteamVR? If you don’t recognize that name, you have not. Verify your change is still there, since SteamVR is known to sometimes delete it. If you haven’t set it, your headset is running at a lower res than it should be.
“Remind: PC Load Letter before using eye-tracking add-on.”
So… What IP class number signifies a device one can drool on?
ACC’s anti-aliasing is just bad. It could have improved since launch(sharpening filter maybe?), but I haven’t touched it since. You either get grease-vision, or terrible aliasing if turning it off.
I have tried every setting that exists(im using an index)ACC and Rfactor2 the problem isnt up close Im getting sharp detail out to about 30 meters the iys blurry as hell in both title ,The supersampling in steamvr is a FPS killer I have tweaked both of these titles ad nauseaum what Im curious about is if the high Native resolution of the 8Kx helps in this or not My system is no slouch.I79700k@4.9MHZ oc twin FE RTX2080s in NVlink(i know its not supported)samsung 980 plus NVME 1tb drives and 64gb of 3200mhz Ram on Ausus ROG maximus code,So this aint my first rodeo,what I really need to know is will the 8Kx and its high resolution clarity help with this Coverman once again thanks for the replies all…
I’m hoping iracing looks fantastic with 8kx.
FYI-You do not need PP in rFactor 2 if you edit the .ini per this post. At least it works for my 5K+.
Currently, there is no abnormal blurring around me.
It’s only the first day and it hasn’t been observed since setting maxRecommendedResolution.
Please verify with multiple titles.
It is necessary to distinguish whether the cause is ACC or steamVR.
Problems encountered only with ACC:
When setting the render quality of PiTool to 1.25~2, ACC’s Unreal Engine crashed with an error.
KartKraft is also Unreal Engine, but it doesn’t have the same issue
I own only PIMAX 4K and PIMAX 8KX
the blurrieness is when you look beyond about ten meters, everything close is sharp and clear,I suspect
its a limitation of the resolution the Valve index is capable of, not the software because Rfactor2 and ACC both have this issue thats why Im hoping like hell the high resolution of the 8Kx will make my racing sims better visually ,ACC the VR support is not native but added later the same with Rfactor2 I dont have this issue with Iracing.
Or even create a script that would make a lot of these changes automatically. Or incorporate them into Pitool so they can be toggled on or off, or set to automatically turn on or off depending on the specific game/app being run.
I have not followed this discussion, but might you have had some prior supersampling set internally in the former title, or in its .ini files (for example r.ScreenPercentage, vr.PixelDensity, or sg.ResolutionQuality), that would bump up the render target size, on top of your PiTool Quality?
I retested a bit now and my carelessness turned on PP checking.
When I removed it, it started normally regardless of the Pitool settings and super sampling settings.
9 posts were split to a new topic: Forum issues (not loading properly)
Moved posts about forum issues to separate topic.
looks so nice an free of cracks
