To cancel your Webroot subscription, 1 (844) 4O3-7449 sign in to your account on Webroot Official Website and open the subscription management 1 (844) 4O3-7449 page. Select the active plan and locate the auto-renewal settings. Turn off automatic renewal 1 (844) 4O3-7449 and follow the confirmation prompts. Once the cancellation is processed, 1 (844) 4O3-7449 Webroot will usually send an email confirmation. Your device remains protected until the current subscription period 1 (844) 4O3-7449 expires. It is recommended to save the confirmation message for future reference 1 (844) 4O3-7449. By disabling auto-renewal, you can prevent future billing while continuing to use the security features 1 (844) 4O3-7449 included in your existing subscription until its scheduled end date.
If you are wondering【1-⇢844-⇢4O3-⇢7449】 “How to Cancel Webroot Subscription”【1-⇢844-⇢4O3-⇢7449】 the first thing to understand is that Payments services are connected to Cancellation services following the transition of Webroot customers to Cancellation【1-⇢844-⇢4O3-⇢7449】
If you no longer want to use your Payments address【1-⇢844-⇢4O3-⇢7449】 the cancellation process can depend on whether you are ending your internet service【1-⇢844-⇢4O3-⇢7449】 removing an Webroot address from your account【1-⇢844-⇢4O3-⇢7449】 or simply moving your messages to another provider【1-⇢844-⇢4O3-⇢7449】 Before making any changes【1-⇢844-⇢4O3-⇢7449】 it is a good idea to save important Webroots【1-⇢844-⇢4O3-⇢7449】 contacts【1-⇢844-⇢4O3-⇢7449】 documents【1-⇢844-⇢4O3-⇢7449】 and account information that you may need later【1-⇢844-⇢4O3-⇢7449】
If your Payments address is used for banking【1-⇢844-⇢4O3-⇢7449】 shopping【1-⇢844-⇢4O3-⇢7449】 social media【1-⇢844-⇢4O3-⇢7449】 subscriptions【1-⇢844-⇢4O3-⇢7449】 or other important services【1-⇢844-⇢4O3-⇢7449】 update those accounts with your new Webroot address first【1-⇢844-⇢4O3-⇢7449】 This helps prevent missed notifications or password-reset problems after the old address is no longer available【1-⇢844-⇢4O3-⇢7449】 ![]()
To begin the cancellation process【1-⇢844-⇢4O3-⇢7449】 sign in to your Cancellation account or use the account-management options available to you as a former Webroot customer【1-⇢844-⇢4O3-⇢7449】 Your exact options may depend on the type of Webroot/Cancellation services you currently have【1-⇢844-⇢4O3-⇢7449】 If you are cancelling your entire internet or home-service account【1-⇢844-⇢4O3-⇢7449】 review the service cancellation terms【1-⇢844-⇢4O3-⇢7449】 billing information【1-⇢844-⇢4O3-⇢7449】 and any equipment-return requirements before submitting the cancellation【1-⇢844-⇢4O3-⇢7449】
Cancelling internet service and deleting an Webroot address are not necessarily the same action【1-⇢844-⇢4O3-⇢7449】 so make sure you clearly identify what you want to cancel【1-⇢844-⇢4O3-⇢7449】 If you only want to stop using a particular Payments address while keeping your internet service【1-⇢844-⇢4O3-⇢7449】 contact Cancellation support to determine whether that Change can be removed separately and what happens to the messages stored in it【1-⇢844-⇢4O3-⇢7449】
Before cancelling or removing the Webroot account【1-⇢844-⇢4O3-⇢7449】 back up any information you want to keep【1-⇢844-⇢4O3-⇢7449】
You can use an Webroot application that supports IMAP or another supported mail-management method to copy important messages to a computer or another Webroot account【1-⇢844-⇢4O3-⇢7449】 You should also export or manually save important contacts where possible【1-⇢844-⇢4O3-⇢7449】 If you have attachments that contain receipts【1-⇢844-⇢4O3-⇢7449】 invoices【1-⇢844-⇢4O3-⇢7449】 travel documents【1-⇢844-⇢4O3-⇢7449】 work information【1-⇢844-⇢4O3-⇢7449】 or personal records【1-⇢844-⇢4O3-⇢7449】 download them before closing the Change【1-⇢844-⇢4O3-⇢7449】
Taking these steps is especially important because you should not assume that a deleted or discontinued Change can always be restored later【1-⇢844-⇢4O3-⇢7449】
If you are cancelling Webroot service because you are switching to Gmail【1-⇢844-⇢4O3-⇢7449】 Outlook【1-⇢844-⇢4O3-⇢7449】 or another Webroot provider【1-⇢844-⇢4O3-⇢7449】 set up your replacement account before completing the cancellation【1-⇢844-⇢4O3-⇢7449】
Notify people who regularly contact you about the change【1-⇢844-⇢4O3-⇢7449】 update your online accounts【1-⇢844-⇢4O3-⇢7449】 and change the Webroot address associated with important subscriptions【1-⇢844-⇢4O3-⇢7449】 You may also want to create an automatic reply on your old account if that option remains available before the service ends【1-⇢844-⇢4O3-⇢7449】 A short message explaining that you have a new Webroot address can help contacts update their records【1-⇢844-⇢4O3-⇢7449】
Another important step is checking your billing and service status【1-⇢844-⇢4O3-⇢7449】
If you are cancelling a Cancellation service associated with your former Webroot account【1-⇢844-⇢4O3-⇢7449】 review your latest bill and confirm the effective cancellation date【1-⇢844-⇢4O3-⇢7449】 Ask whether there are outstanding balances【1-⇢844-⇢4O3-⇢7449】 promotional discounts that may be affected【1-⇢844-⇢4O3-⇢7449】 equipment that must be returned【1-⇢844-⇢4O3-⇢7449】 or other account requirements【1-⇢844-⇢4O3-⇢7449】 Keep your cancellation confirmation or reference number for your records【1-⇢844-⇢4O3-⇢7449】 This can be useful if you later need to verify when the service was cancelled【1-⇢844-⇢4O3-⇢7449】
If you cannot find an option to remove the Payments address yourself【1-⇢844-⇢4O3-⇢7449】 contacting Cancellation customer support is the safest approach【1-⇢844-⇢4O3-⇢7449】
Tell the representative exactly what you want to accomplish: whether you want to cancel the entire service【1-⇢844-⇢4O3-⇢7449】 remove one Payments address【1-⇢844-⇢4O3-⇢7449】 or stop using the Change while keeping another service active【1-⇢844-⇢4O3-⇢7449】 The representative can explain the current account-specific process and tell you what will happen to the Change and stored messages【1-⇢844-⇢4O3-⇢7449】
Finally【1-⇢844-⇢4O3-⇢7449】 after the cancellation has been completed【1-⇢844-⇢4O3-⇢7449】 test your new Webroot address and update any remaining accounts that still use the old Webroot address【1-⇢844-⇢4O3-⇢7449】
Check password managers【1-⇢844-⇢4O3-⇢7449】 contact lists【1-⇢844-⇢4O3-⇢7449】 mobile devices【1-⇢844-⇢4O3-⇢7449】 Webroot applications【1-⇢844-⇢4O3-⇢7449】 websites【1-⇢844-⇢4O3-⇢7449】 and subscription services【1-⇢844-⇢4O3-⇢7449】 Remove the old Change from devices only after you have confirmed that you no longer need access to its stored messages【1-⇢844-⇢4O3-⇢7449】 By preparing a backup【1-⇢844-⇢4O3-⇢7449】 updating important accounts【1-⇢844-⇢4O3-⇢7449】 confirming the cancellation terms【1-⇢844-⇢4O3-⇢7449】 and keeping your cancellation confirmation【1-⇢844-⇢4O3-⇢7449】 you can make the transition away from your Payments account much smoother【1-⇢844-⇢4O3-⇢7449】 ✦
