I recently got the chance to buy a used XTAL 5K unit, could´nt resist and pulled the trigger.
After some time with getting used to the VR Tool Software and getting Steam VR working with my XTAL, I had my real first session with the Headset and encountered some eye strain and IPD issues.
I could only use the Headset for around 90 mins, before my eyes really started to hurt. I felt dizzy and neusea the rest of the day and even on the hole next day.
I set the focus wheel of my XTAL 5K to the point of the for me sharpest picture quality and the for my eye most comfortable position. Also tried the most comfortable IPD value for my eyes.
My XTAL 5K unit has the same lenses as the XTAL 3, which ones solved the most problems people had in the past with the older lens systems from VRgineers, at least I heard that from some other users.
I do not know I can resolve that. I have the same issues with my Vive Pro 2. I never had this kind of issues with my quest 2 but had this also happening with my 8KX, if I did not set the IPD correctly.
On my 8KX I set the IPD to 64.2 mm and could use it for long sessions without any problems.
My normal IPD is 68.5 mm. Tried this setting also on my XTAL but without any success.
I guess this could be related to the binocular overlap? The Vive pro 2 does not have the best binocular overlap, but could not find any informations for the XTAL 5K and the XTAL 3 lenses.
Beside that, the FOV and true blacks of the XTAL 5K are awesome for space games, if I get these issues resolved, I have the perfect HMD for me. Also the 3D effect is much better for me personally than compared to my dead 8KX.
I am open to any recommendations, many thanks!
@Djonko BTW, how went the thing with the prescription lens inserts for your XTAL 3? If I remember correctly, you had some issues with the very short focal distance length of the XTAL 3 and you were in contact with VRgineers to get these prescription lens inserts to get rid of that problem? Was it a success for you? I’m just curious ![]()
