Enhanced VR Depth with OpenXR 3D Boost MOD
I am new to Pimax (Play) and various OpenXR runtimes. How do we use with with the current Pimax Play?
Or do I need to use the older mbucchia OpenXR Toolkit, and other software? to make this work.
Thanks for pointers on this subject.
UPDATE: I was able to get this working. Leave Pimax Play running, and then run the OpenXR Toolkit. That is all you need. But testing with the 3D settings made my UW module unusable, the crossed-eye distortion was extreme, even on low settings like ‘6’.
This is a great plugin, but don’t overdue it. In our sim racing center we run it with iRacing but only 7% boost with 100% world scale(no idea why would you increase scale) and advance fov(don’t have to change anything there). We cannot race without it anymore. Best way to set it is to drive Nordschelife and increase it by 1 point every 2min :slight_smile: . At 8+ boost road closest to you is warping too much, at least with pimax crystal light.
// I was wrong, 8% boost and 110% world scale is perfect.
