Im trying to install beta firmware for 90hz on my 8kx. It says to use dfu.exe, but theres no dfu.exe. What do I do?
C:\Program Files\Pimax\Runtime
I had the same issue with the latest pitool, I uninstalled it and installed the one before and the dfu.exe was in the folder. I update the firmware and then updated to the latest pitool
where did you find older versions of pitool? i can only find the latest.
You might be able to find some here:
Yeah its weird. Why did the latest Pitool remove Dfu.exe? @PimaxQuorra
Hello,
For the firmware, you need to download from this site.
It’s a different firmware from the official site.
Sincerely.
Hello,
There’s no DFU in the latest version file?
Sincerely.
I had the same issue three weeks ago when updating:
No DFU.exe in the aforementioned directory as it used to be formerly
Sorted by name. Red arrow indicates where I would expect it
This is the only result I get when searching in the directory and its sub-directories:
Hello,
We gonna check with the Pitool team on the missing DFU.
Sincerely.
Hello,
We have an update from our Pitool team, the DFU.exe is currently removed for this version.
But we will have a better DFU.exe for the upcoming Pitool version.
Sincerely.
