@PimaxQuorra
Can you please post the actual Render Resolution per Eye of the Super UW with the actual distortion profile in PiPlay 2.01?
Can´t find any offical informations about that.
This would help a lot to fine tune performance using the OXRTK Override feature instead of using the PiPlay options. Specially for MSFS2024 where Quad views is used and a resolution is required which must be dividable by 2 to not have wobbling when set to 25 instead of 50.
So what is the 100% Resolution for the Super UW in actual distortion profile?
Overlay is showing 6812 x 6502. Is this correct?
