Crystal Super mOLED upgrade from OG Crystal
Credit: PfizerBiontech857
Recieved my mOled Super today,initial impressions after about 8 hours of use.
from opening the box,its much better packaged than crystal light was wich even came with the strap holder broken back in 2023 or my 8kx
Comfort
the build feels more premium and i was blown away about how much lighter it was,feels less than half lighter than the original crystal with the battery bs,this alone was a reason to upgrade,albeit when i first put it on and used it was less comfortable the foam is pretty hard pressing on the forehead and it felt hot like i had a fever as it is hotter,but after putting the apache strap and studioform foam its night and day,could proly wear this for 8 hours without a problem now.
visuals
there is glare but not that bad its different than other pancake lenses i tried,its more at the edges but the perfect blacks and colors makes up for it,the og has zero glare but the local dimming blooming looks much worse.
Brightness wise,i was again surpised,its literally brighter,colors and highlights pop alot more than the og crystal on extreme local dimming setting,i was worried itl be much dimmer but not at all and that contrast is sweet the colors are much more vivid.
Distortions were there,at first quite noticeable as if the world moved weirdly in waves,but after adjusting my ipd a bit lower,its minimal crystal had zero for me but its not an issue now,i dont like the ipd adjust is only in the software instead of the volume buttons,its harder to get it right and i couldnt find the auto ipd button in pimax play but eye tracking is working in the calibration.
Clarity wise it is phenomenal full edge to edge for me,crystal had a huge sweet spot but nowhere near like this also the mOLED has ZERO MURA wich was an issue for me with the og in daylight scenes thats why i didnt get the qled super.
the PPD increase aint as noticeable as when i upgraded from 8kx to og crystal,but you can tell there is zero SDE,the lack of mura and imperfections is whats the most noticeable.
i dont see any color shi/t or chromatic aberation,there is a little darkness in the middle if not positioned correctly but it goes away when youre dialed in.
also the 3D effect is a bit better for some reason proly due to the perfect contrast as on paper it doesnt have much bigger overlap.
FOV i measure 94v and 112h vs 100v and 100h for og crystal,not a huge upgrade but i can feel its wider while not really noticing the bit lower vertical fov,the edge to edge clarity also helps to feel that its wider and in darker scenes the perfect blacks also because the dark blends in with the outside dark,the FOV is more immersive.
Sound it comes with those useless speakers they arent even worth mentioning they are worse than 2$ phone ear phones,it should come with the DMAS by default for this price,i used the og crystal DMAS and it works as normal and sounds amazing,even better as it doesnt seem to have that little sound lag from the OG.
Tracking is usable,but im waiting for the LH plate
Overall it was a great upgrade for me and really worth it specially with OG crystal owner discount code for the rest of the payment i havent done so yet as i still got 13 days to test.
i hope it remains the same with no issues and that they make replacements cables,like the crystal had,a bit thinner as this one is kinda thick and rigid.
