Am I the only one…..
First, my setup is high end system with 5090GPU, 14700k, 64GB 6000Mhtz ram, fast 2TB SSD, 1100W PSU
I have come form Meta quest, to Crystal Light, now to Crystal Super.
Many hours watching all the videos i can find including those from Martin.
My game of choice is LMU, although have tested in iRacing, ACC and Auto2
I do not get any improvement in visual and performance when turning on the new features.
I have tested PimaxXR as well as OpenXR
Making adjustments in both.
And… what i find particularly frustrating is teh narrow focus point in teh goggles, small area that is clear.
With the super, i am running at 100% resolution and 90Htz.
Low GPU timing, under 10
CPU utilization just over 50%
GPU utilization maybe 70%
If i try an increase in game settings to more than low and medium, frame rate drops.
So, is it me?
Does Pimax have a set of config options that have been tested to produce certain results?
Sure will depend on many factors, but any PC of my spec should get a result that will be similar.
I am not experiencing what i need form such a high cost setup?
Other thing with setup, there are so many videos, not consistent with recommendation, and sometimes wrong.
One I saw claiming to be able to provide teh best result setups for all refresh rates, but not even knowing or testing PimaxXR, just using OpenXR.
Interested ion peoples experiences …..
If i have missed something , would live to be told!
