Crystal Super Double Vision with SteamVR
Hello, running a PCS with latest firmware, using Pimax Play (PP) ver 1.43.4 and SteamVR beta 2.14.5 , and I am getting double vision when running Xplane 12 under SteamVR. This only occurs under SteamVR. I have Half Life Alyx and when running that it displays normally.
When running SteamVR I shut down Pimax Play, so it is not running.
I really only run Xplane 12 in VR, I’m not into other VR things at this time.
If I run Xplane directly from PP this does not happen, visuals are great.
So while I have a working method to run Xplane I just have been unable to figure out how/why my VR image is doubled, and how to fix it.
I appreciate any suggestions, thanks
I did some searching and one suggestion was to set Pimax Play to ““Compatible with Parallel Projections” to ON” . However this setting is not in the current PP version.
