I picked up a new rig in March and up until recently, it only got very light use. However, I recently started doing some regular VR simming and I began having an issue where the PC would randomly reboot itself. No error message or anything, just a sudden, clean reboot. It could happen while I was running a game, or while I was doing nothing, for instance, shortly after a normal boot process. I did check the system logs and saw there were critical errors causing the reboot due to an Event 41, Kernal-Power issue with a bugcheck code of zero.
I brought the PC back in to the retailer, they ran all sorts of diagnostics and found nothing wrong. I brought it home and not long after, the problem started again. Also, after a few reboots, its not uncommon to lose video signal altogether. If I shut down for awhile, it will boot normally again. In any event, I unplugged my crystal super Micro-OLED and have not experienced the problem since.
System specs are the following:
AMD Ryzen 9 9900X3D 4.4GHz Processor
MSI Mag X870E Tomahawk WiFi
NVIDIA GeForce RTX 5080 16GB GDDR7
64GB DDR5-6000 RAM
2TB Solid State Drive
Microsoft Windows 11 Home
360mm AIO Liquid Cooler
1000 watt PSU
In addition to the VR headset, I also have a triple monitor setup and the system is connected to a KVM switch with two other rigs. Both other rigs run fine.
Have you done the usual troubleshooting, like isolating the machine to be no kvm, a single monitor, default BIOS setup, GPU running at stock speeds, etc?
I’m in the process of doing that now, I suppose. I started with unplugging the crystal. So far, the problem has not occurred with the crystal out of the ecosystem.
Since I want to actually use the crystal, my next test will be to reincorporate the crystal and perhaps unplug one of the monitors.
I guess I’m also wondering if anybody else has had this problem or heard of it being a possible problem.
Kernel voltage sounds to me like when the CPU is being pushed (using the headset) some voltage regulators are messing it up. You should check your BIOS CPU configuration. Do some CPU-Z stress tests without the headset and see if it also then occurs.
I did a “CPU-Z” stress test and all appeared good. Everything remained steady and there was no reboot. However, I only ran it for a few minutes. How long am I supposed to keep the test going?
If all bugcheck parameters are “0” then I would test your memory. The reason I mention that is because in some cases you will get that because of the stop error and the dump file doesn’t get written. Check the event viewer for an error 6008 before the 41. Check the mini dumps and see if anything was written. Use Whocrashed app if needed. If memory tests show everything good then I test the rails on your PSU.
A kernel problem indicates a power fault. In Event viewer you may see a fault with nvlddmkm. This is the Nvidia driver which will always fail after a power issue. I had this problem around eighteen months ago and it drove me crazy trying to find a fix..I eventually upgraded my PSU from 850W to1200W and have not had the problem since. I would have thought a 1000W PSU should be plenty, but VR is very sensitive to power fluctuations.
I’ve been having the same issue. PC just reboots when in VR mode with Pimax Crystal Super Micro-OLED. No blue screen, just straight to reboot. I assumed it was because of MSFS 2024 pushing the 5090 and i7-13700 to the max when in VR, but, and this is the rub, it also happened when I wasn’t playing anything and just doing the eye calibration in Pimax Play/Evo (can’t remember which). I’ve since gone back to Balanced mode, from Performance mode, in AWCC and so far so good. I’m also now logging every VR session with HWiNFO to see if this gives any clues. If I do find a cause, I’ll add it here.
Thank you. For the record, mine will also reboot when I’m not actually running anything in VR, but what I noticed is that just having the headset plugged in with Pimax play running seems to tax the system. Nothing crazy, but enough to make all the fans spin pretty noticeably. This is why I decided to start troubleshooting by unplugging the headset and since, I have not had any reboots, despite running some pretty intensive non-VR games.
Looking forward to any more insight you may develop.
Just FYI I’ve not had any of the reboots since switching to Balanced from Performance mode in AWCC. Perhaps pushing my PC to run in Performance mode PLUS run the Crystal Super Micro-OLED was just too much for it. Perhaps Pimax fixed something in one of the Pimax Play/EVO updates.
