Automobilista 2
Cool thanks, I will try that tonight or tomorrow night :slight_smile:
It´s a game changer :+1:
What Wheel do you use? I was lucky to get a used Fanatec Elite on EBay after looking for years.
The Moment I read that they where aiming to compete with Forza and co. it died for me. My Boys play Forza Horizon and Crew 2 - nice games for arcade style driving - no need for a try with PC3 in my opinion. Its sad, I really would have loved them to go deeper down the sim racing lane. If they then also include an “arcade” mode, fine - but it smells like arcade mode and then if you want we pretend to be a sim also. Well I got ACC und AM2 - that will be fine for many enjoyable hours.
I still have hope that ACC also includes LMP’s in some time - I love the FIA World Endurance Championship races - I live near the Nürburgring and went to watch the 6 Hour race’s a couple times - its an awesome mix of cars and really nice for the family (ok, the boys in the family) since its very affordable and very interesting - its like 20% of what F1 would have cost and much more diverse in cars and the race.
Nice wheel! I have access to a Simcube 2 pro just around the corner. At the moment i´m still using my Thrustmaster T-500 RS until i saved some money for the Simcube 2.
I had the T-300 before, it was also nice, but the Fanatec is definitely an upgrade worth it :-). The Simcube is a bit over my budget :wink: after all the VR Upgrades.
Anyone tried AM2 in Oculus mode on his pimax so far?
Ok, you got me - drives really nice - still need to get used to the setting and cars, but there is enough to have lots of fun. Some cool tracks that are coming, cant wait for the Nürburgring to appear, especially the if they add the nord schleife :slight_smile:
Yep. Missing it. Good that i bought the deluxe version with season pass. Coming soon! :crazy_face:
You mean running it with the steam_appid file with 1066890 inserted and placed in in the Automobilista 2 folder ?
I did try it but could not turn off PP - maybe I missed something.
Edit: I found this and tried it (except the oculus libs, since i have it installed), but nothing happens:
EDIT: It WORKED! - must have made a mistake
I just used the link directly and it works
“C:\Program Files\Pimax\Plugin\OCSupport\OVR_Launcher_x64.exe” J:\Program Files (x86)\Steam\SteamApps\common\Automobilista 2\AMS2.exe -useoculussdk
what link do you mean? i have maked the steam_appid txt whit 1066890. is this -useoculussdk in start launch?
do i need this files to Lib_OVRRT32_1-.dll and Lib_OVRRT64_1.dll_
  1. I created the steam_appid.txt in the automobilista 2 folder with 1066890/othervr as text in it.
  2. I made a link in the automobilista 2 folder named AMS2Oculus (name it what you like)
  3. Edit the Path of the link to what @MarkkuE said in my case “C:\Program Files\Pimax\Plugin\OCSupport\OVR_Launcher_x64.exe” J:\Program Files (x86)\Steam\SteamApps\common\Automobilista 2\AMS2.exe -useoculussdk
Double Klick the new link
I am not sure if that is all needed, I guess it works without the appid file? With that I do get Oculus Mode in Steam, but it starts in Steam VR none the less, even if i select it and PP is needed.
told you :heart_eyes:
Yes you did :grinning: :+1:
Edit: The Profile is also very nice! Thanks, it helps a lot!
okey i got a message , when i try to save Path “C:\Program Files\Pimax\Plugin\OCSupport\OVR_Launcher_x64.exe” J:\Program Files (x86)\Steam\SteamApps\common\Automobilista 2\AMS2.exe -useoculussdk in the short cut from OVR_Launcher_x64.exe. its says i got wrong path file . i can`t save the new link in the short cut.
thnx for help
Is that correct that you also have it on drive J?
no, i changed this to c:/
Have you tried to set it all in quotes instead of ending after the first part? Then change it again once it’s created
i get it to work now . thx
but i struggle whit pitool 1.0 to get 90hz 2080ti 8700k 32g 3600mhz
