Assetto Corsa ideal settings for 8KX?
This is solely regarding OG Assetto Corsa, not ACC.
I’m running AC via Content Manager, SOL patch and Natural Mod.
With a 2080Ti @ 2GHz I was able to run challenging scenarios (Night, 10+ cars, 4xMSAA, high to ultra settings) at PiTool 0.75 and maybe 75-80% SS on the 8KX whilst maintaining pretty close to 75fps.
My 3090 clocks pretty damn well, considering it’s not even under water yet and maintains a stable 1.98 GHz under full load including a +650MHz offset on the memory. PiTool 1.0 and 100%SS is not an issue, at PiTool 1.25 and 100%SS it starts dipping into the 68-73 fps range.
Has anyone done any more finetuning on a similar setup?
Using the integrated AC benchmark is not advised BTW, I don’t know how it renders differently but the load it applies is 30-50% lower than real world scenarios.
I have I7 32gb and 2080ti there are 2 days I’m tweak the 8kx (I have shaker and dof too)
Content mangager, sol, and patch shadow… forgot the name
Really I don’t know what the different to use natural mod… if use it you esclude sol effect?
If you think is better then I must try,
I use ptool 1.5 and 100super sampling and the news is that turning on the "turn on smart… " the funciotn of ptool it work very good with 8kx (with 5k+ I don’t like) the fps is locked at about 37 but very nice to see specially in big curves It conitnuos see lock without lost quality
I set alias 4 and the msa too… ultra al video setting real mirrow hq ecc
and then the visual is perfect
Of course depend of the track and how many car. (some external track have bad fps in pratic mode too
I have same question maybe you can help me
If you can explain what better in natural mod, thank you
and another problem if I set rain… the wipers is move and the sky look bad but never see tha rain… what’s wrong?
I have many track buyd from a converter (like grid tracks, Milano Roma, Las vegas) but many track have very low fps alwasy… Is there a way to fix it?
About the graphic man that auto move to the gear when is ready to need change? It’s possible to fix and move only when I real change gear?
Another my problem is that often the 8kx (and 5k+ too) go out of centre and during driving I must press the reset position (assign to whell) Maybe because the dof movement?
