Anyone else still experiencing stutter issues with all versions of pitool later than .95?
I am still experiencing extreme stuttering when turning my head in any game on any pitool later than .95. I am curious if anyone else is experiencing this? Also if you have managed to find a fix for it please let me know. I would like to be able to take advantage of the extra features and reduced screen tearing than what I am currently experiencing in .95 but the stuttering makes the new versions completely unusable.
Hi. Have you tried a complete fresh install of the pitool? I had problems after updating but then I deleted it and installed fresh it was fine.
No stuter on beta 111 and stabel 112.
uninstall all, and after that erase the pimax folder into app folder/your user name
Restart and install 111 beta
@Joeblackof @_c_c Yes anytime I have updated it has been a completely clean install.
Same here. Uninstalling, restarting, reinstalling and still no fix. No games running, just SteamVR grey screen and it still stutters when looking left and right quickly, but GPU, CPU and Mem are all under 60%
no big deal stuttering with .111 here.
In SkyrimVR i got used to play without smoothing though, because it runs smooth without, even tho i have only 25-35 fps some places and depending on mod setup. I cant explain why that is, but game looks smooth with 25 fps. Weapon swinging shows ghosting but thats okay.
I guess its Pimax secret sauce, why i’m not vomiting @25FPS
Vive wouldn’t do that at all for me.
No stuttering either with 109 or 111. Try using DDU to remove your GPU drivers and then reinstalling clean.
Edit: I had issues, incl. stuttering, initially with Pimax, reinstalling SteamVR (non-beta) sorted that out.
Yes I am exactly the same - fresh installs etc etc - still getting the juddering. Started with the first Brainwarp beta and nothing has fixed it.
yep even happens in pimax’s own vr world
tried this today as well unfortunately I am still getting the stuttering
killing LightingService.exe if you have Corsairs iCue or Asus Aura (I had this) installed, which was my solution.
