AMD GPU Drivers and OG Crystal - 90/72 Hz Color problem fixed (I think)
Hello, figured I might mention it here because I couldn’t find a thread.
It would appear that the Adrenaline 26.1.1 drivers solved the problem with the OG Crystal showing inverted/”acid trip” colors on the whole display when used in display mode other than 120Hz. I decided to try 90Hz because I’m having other connectivity issues and it displays well even in SteamVR, same as 72Hz now. However, said drivers have introduced flickering artifacts in 120Hz mode and I’ve yet to test the other refresh rates for more than a few minutes.
Thought you all ought to know :slight_smile: (but feel free to correct me on any of these observations, or if anyone else can confirm the same that would be great).
Edit forgot to mention I’m on an XFX 7900XTX. Sorry.
So even after switching to 120 Hz, the flickering issue is still there. I’ll report this to the devs.
