8Kx borked out by 595.79
I know 566.36 is the last known good driver and that’s what i’ve been using. But i wanted to play a flat game and get better performance so i loaded 595.79. But now , even after rolling back to 566.36 it no longer sees the DP cable is connected. I’ve done the DDU thing, i’ve even installed a new win10 with just 566 and Pimax Play and it doesn’t work.
595 modified something in the GPU that will not roll-back . I have 2 8kx Dmas units and 1 5k Plus and none of them work now post 595.75
595.79 did a display port firmware update for DP2.1 that changes Display Stream Compression (DSC) handshake logic to v 1.2a
Modified HDCP to 2.3 DRM handshaking protocols
The way the hardware polls for VR Head-Mounted Displays (HMDs) via the DisplayPort interface was fundamentally changed. The new protocol expects a specific response timing and signal signature that older VR headsets often do not provide I think this is EDID related changes.
This things don’t get rolled back going back to 566 so once you go forward to 595+ you’re F’d it seems like.
anyone got fixes for this display port unplugged issue that aren’t just rolling back drivers/UDD things? My problem is deeper than that, we’re off in the deep end here for fixes the low hanging fruit options have all been tried at this point.
Did you reach out to our tech support?
If this proves s Nvidia driver try the latest driver
