8K+ vs 8KX [why must titles be min 15 chars?]
What is the main difference between the 8K + and the 8K X? I own the + and I saw a web page that looks like it is the same specs.
8k+ is upscaled only from Qhd to 4k Uhd per eye.
8kX can do Native 4k Uhd or Upscaled.
If you own an 8K+, there’s not much need to get an 8KX. As Heliosurge mentioned, the 8KX does full 4K res per eye at 75 or 90 Hz. It also has a fallback mode to do 2440p per eye; that mode is basically the same as your 8K+.
So screens are the same?
And what is the difference 8K+ and Vision8K+?
Not sure. They have the same resolution as the 8KX.
Maybe @anon57422158 or @hammerhead_gal could answer your questions.
For exapmle i saw (i and tested both headsets) that 8k, and vision 8k+ have the same displays resolution. But for me, there is a huge difference between pixels density.
Or maybe i found bad specifications?
  • Og 8k had a pentile like display
  • 8k+ has same panels as 8kX but upscales like og 8k. 8k+ are Vision model.
  • 8kX does Native and upscale.
15 chars :+1:
