I know a ton of people are worried about Pimax Qled 12k not having OLED contrast, and being an LCD, but there is some stuff the engineering team and forum members should consider.
Since the Backlight is supposed to be “HDR” and because 12k has local dimming, it can be very useful for backlight strobing. Good strobing will halve overall brightness, but it also increases percieved contrast closer to the max nativebof the panel, say 100000:1. Because in a stobed back light the backlight is off most of the time mimicking an old style Raster scan impulse driven display like a crt.
Lets say that the local dimming algorithm isn’t that great, or isn’t capable of dramatically improving picture contrast without blooming or artifacting like was mentioned with Aero.
Even if that were the case, tuning the LCD for good backlight strobing can make excellent use of the fald backlight for improved contrast and also increased motion clarity. You can also hide slow pixel transition times in darkness. That really improves picture quality on an LCD display. Just read all the articles on blurbusters.com
I would recommend, read insist that pimax should get in touch immediately with Mark Rejhon from blurbusters.com and have him help you strobe tune your LCD.
Not that I’m implying that pimax won’t have a good handle on its FALD algorithm, but let’s say it isn’t perfect, the new characteristics of this display could still be very useful for overall improving the headset picture quality.
Let’s say that the backlight can hit 350-400 nits for full screen white. Let’s say that’ the highlights could hit 800 nits in 1 dot.
If you optimized the backlight to strobe using that 800 nit flash, you could get very high motion clarity, still get good brightness of about 100 nits, and the contrast would be excellent because the backlight is off most of the time.
I have my 144 HZ LCD overclocked and strobe tuned at 165hz and with that I have top to bottom image clarity even while an image is panning at 1200 pixels per second on blur Buster’s test UFO.
My monitor is not HDR cable like this VR LCD is, so if pimax does this right, they could give us a very high-quality picture with this thing’s fancy backlight, even if the local dimming wasn’t perfect.
