# Where to get a good deal on index controlers and base stations?
**URL:** <https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068>\
**Category:** Controllers\
**Tags:** hand\
**Created:** [February 8, 2022, 8:00pm UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068 "2022-02-08T20:00:46Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jasonkane](https://forum.openmr.com/letter_avatar_proxy/v4/letter/j/c37758/32.png) [@Jasonkane](https://forum.openmr.com/u/Jasonkane)\
**Post date:** [February 8, 2022, 8:00pm UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/1 "2022-02-08T20:00:46Z")
</div>
HI I just bought a Pimax 8kx and want to know if anyone know a place to get a really good deal on the index controlers and bases stations. I cant seem to figure out how to order them on the pimax website without ordering the headset aswell. Everywhere else but the pimax website, thet set is much more money. Thanks
**Post date:** [February 8, 2022, 10:17pm UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/2 "2022-02-08T22:17:11Z")
</div>
For Index Controllers with Lighthouse Combo likely best through Steam/Valve as no concerns with potential import fees.
Otherwise maybe ebay?
**Post date:** [February 8, 2022, 10:59pm UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/3 "2022-02-08T22:59:08Z")
</div>
Thanks. Ive been checking ebay prices for a view days. The prices are crazy. Usually around $800 total for controllers and base stations, even the used ones. Do you know if its possible to get the $500 price, from pimax, without buying anything else?
**Post date:** [February 9, 2022, 12:15am UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/4 "2022-02-09T00:15:47Z")
</div>
To be honest you would need to maybe try pimax support with a ticket and see what they say.
@PimaxQuorra maybe able to help. A lot will depend on there policies and procedures I imagine.
**Post date:** [February 9, 2022, 7:42am UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/5 "2022-02-09T07:42:45Z")
</div>
Hello,
If you’ve purchased the headset from our website, and you need the controllers and base stations, I’d suggest you to file a ticket with our support.
Telling them you need the remaining items, and they should be providing you the quotation that cost lower than Ebay.
> **[Submit a ticket](https://support.pimax.com/en/support/tickets/new)**
**Author:** ![SmallBaguette](https://forum.openmr.com/user_avatar/forum.openmr.com/smallbaguette/32/24247_2.png) [@SmallBaguette](https://forum.openmr.com/u/SmallBaguette)\
**Post date:** [February 9, 2022, 10:42am UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/6 "2022-02-09T10:42:07Z")
</div>
I would recommend trying to find cheap secondhand 1.0 base stations, instead of 2.0. Might shave the cost down. If you can, buy the index controllers new direct from valve as you’ll likely need to RMA them at some point.
**Post date:** [February 9, 2022, 5:25pm UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/7 "2022-02-09T17:25:51Z")
</div>
Thanks. Sadly Valve is out of stock. So I need to buy them elsewhere. Luckily I just found a used set locally.
**Post date:** [April 10, 2022, 5:25pm UTC](https://forum.openmr.com/t/where-to-get-a-good-deal-on-index-controlers-and-base-stations/38068/8 "2022-04-10T17:25:56Z")
</div>
