When will 8K DP1.4 model be available to customers?
@deletedpimaxrep1 I have decided not to buy the 8k kickstarter model due to lack of native 4k support
You confirmed a model with DP1.4 will be available later
Can you tell us when that will be available to consumers??
Thanks
To clarify it Will have DP1.4 available but they need two of them for native 4k
Yes and they have indicated they will release a model that will have 2x DP
Probably sometime in 2020 along with the scent and wireless module
For the 4k per eye. Good thread @Davobkk
I imagine we will probably see the dual dp 1.4 by q3 2018.
Is it a horrible idea to get the 8K X?
I just ordered one.
Correct me if I’m wrong but the headset that will support native 4K per eye if you got the horsepower to run it is the 8K X right?
Or is the 8K X still upscaled. That would be massively disappointing.
It will be capable of 4k native. it will have 2X dp1.4 cables
Correct, X version supports native resolution and you need a proper amount of horse power which is equal to next gen Volta 2080gtx.
Industra. When do you pay for shipping on kickstarter?
So the 8K is the 1440p upscaled and the 8K X is the 4k native?
I plan on getting a Volta when I have the money considering this thing ships in may I have plenty of time.
Yes that is my understanding - I have ordered the 1440p upscaled and will probably do the upgrade to the “8K” native in the future when I know what GPU I will have at the time.
Well, you pay all in once. Need to check our cards at the months end. It’s either ‘its already charged’ (or will be at the end of campaign) or will be days/weeks before they start to ship. Not really sure if i understood the question correctly.
They charge at the end of the campaign from what I know. But you should consult other people I generally avoid kickstarters.
have you been charged yet?
my banking site wont update it so quickly
569 in my case.
