I love to use Openvr, and use advanced settings an playmover, however I’ve been unsuccessful in finding any version that work with the Pimax, pitool. Most versions crash upon usage.
Valve changed things openvr advanced settings needs a patch.
Thank you my dude
works fine on my pimax 5k+ Releases · OpenVR-Advanced-Settings/OpenVR-AdvancedSettings · GitHub
Are you using latest steam? If yes which openvr advanced settings version are you running?
i used the linked one:
Latest Steam (no beta) with SteamVR 1.2.10 (nobeta)
and i use the Chaperone Profile function:
