Two helpful things that I created to make my Pimax VR experience better
Auto set mouse trails and Auto disable all USB sleep batch files. Both run at the start of windows to ensure that my mouse trails is on at the lowest settings (which keeps the mouse visible) and Auto disable all USB sleep settings (goes through all USB settings and ensures all are set to not sleep)
The USB ps1 has a bat with it that you only need to run once, it will make it a scheduled task.
The mouse trails you can manually add as a task or just run it once each time you log in.
