Tracking Issues April 2020
I ordered this 2m hooked cable to connect to the headset https://www.amazon.nl/gp/product/B07PHGS5W6/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
And nice tip to secure it into the controller, thanks!
For what it’s worth, flashing my old Steam Controller dongle to a Watchman dongle and pairing the right Index controller to that seems to have completely solved my tracking issue in Beat Saber. The dongle is just plugged straight into my PC, not the headset.
@Leonardo any news from pimax about this issue?
Or from anyone else, did someone got an Answer from Pimax?
I mean, it is obvious a lot people have issues right now.
I use something like this and velcro tape to stick dongle on my headset.
No more lost tracking issue.
I try to get news every 2 weeks or so. Last I heard I posted on this thread wich is very active:
https://community.openmr.ai/t/why-pimax-has-some-controller-compatibility-issues-with-index-controller-some-info/24313/202?u=leonardo
Last contact about my ticket is a week ago, when Alex asked more information about firmware of controllers and my HMD s/n.
Just keep in mind this issue is also affecting some vive and index headset owners as well.
Blockquote Just keep in mind this issue is also affecting some vive and index headset owners as well.
I have 2 external dongles when I use my pimax I get disconnects, when I switch to Vive Pro i don’t get any disconnects. Same dongles paired to the same controllers. Which would indicate there is a software issue.
If your having to use Dongles vs the headset ones. Then sure being that this would be on Valve’s Software than Pimax’s.
As said some Index and Vive’s are also affected. Why the issue isn’t consistent with all headsets with a given manufacturer suggests a likelihood of maybe different revisions of internal dongles.
This is hands down the biggest BS i’ve heard in a long time. The dongles bypass Pimax’s PiTool. That’s what makes them work. Because the headset and software that Pimax delivers you is incapable of handling 2 data streams at a time. It’s not related to Valve in any way. It’s the Pimax hardware/software and we all know it. If it was an issue with Valve, then my Index wouldn’t have worked perfectly with the exact same base stations and controllers.
I would like to see the source of the vive’s and Index’s affected though. I’m highly sure that you haven’t read those topics and that they had issues regarding their base station placement or reflective surfaces. Never had these two headsets had any connection issues with controllers. There has been a bad batch of index controllers at the start, but those disconnect in a different way that is easily noticable over the issues that pimax headsets have.
Pimax needs to stop this BS and give people a proper fix. They know this issue is happening, they are just hiding from it with excuses so they don’t have to fix it. We are talking about a premium priced headset here and the support is utter garbage. I’ve been trying to contact Support in a gentle way for 3 months now and they won’t even bother to respond or give me an automatic sh*t reply that is not even close to the answer. I can already bet you that it’s a hardware issue that they are never gonna admit. They are probably gonna fix it in the newer headsets by replacing the Watchman dongle and call it a day. Not helping any of the current owners because i can already assure that they can’t even afford to replace a quarter of all the defective units(which is every pimax that exists).
I’ve put mine on sale. I’m done with this sh*t company that won’t even support their clients. Biggest waste of money, period. If someone from support would actually want to reach out to me, shoot me a message. But i guess that also will never happen because why would i even have any expectations from this company?
Advice for the future: Admit your f*cking faults and fix them in a timely manner. This had been going for over a year. This shady mess is doing the business nothing good and it’s just waiting for bankruptcy at the moment because they are to lazy to fix their mess that they made over the past years. .
Have you heard of using Google and Reading Reddit?
Here you go.
https://amp-reddit-com.cdn.ampproject.org/v/s/amp.reddit.com/r/ValveIndex/comments/c98m4u/index_controller_tracking_issue/?usqp=mq331AQQKAGYAbm1tM2rlJy_U7ABIA%3D%3D&amp_js_v=a2&amp_gsa=1#referrer=https%3A%2F%2Fwww.google.com&ampshare=https%3A%2F%2Fwww.reddit.com%2Fr%2FValveIndex%2Fcomments%2Fc98m4u%2Findex_controller_tracking_issue%2F
Folks like yourself need to stop jumping to conclusions. Which BTW Tracking Pucks show up in pitool and pair with Dongles.
After @anon57422158 said it was also affecting non pimax headsets I did my diligence and used a search on google.
Google: Index Controller Tracking issues
Did you know pimax was not the first result?
Did you check this topic? Was due to him accidentally pearing the controller to one of his vive tracker dongles instead of the headset.
Was related to the motherboard used with incompatible USB ports. Not the headsets fault.
This one is interesting. But also shows that different hardware fixed his issue.
Topic created the same day as the user made a request. He also didn’t respond after at all. So he probably figured it out and was just new and had a setup error
He states having issues regarding his light situation. This leads me into thinking it’s a reflection issue. Otherwise it wouldn’t make a difference.
All and all i really liked the Pimax headset. But i’m just tired of the issues. And we all know that it’s happening on a way larger scale with pimax headsets than other brands.
FYI, my pimax works fine with Vive 1.0 base stations and wands. But with 2.0 base stations and Index controllers, it messes up. This is probably due to the headset dongle not being able to process all incoming data which is way higher on 2.0. Logs also confirm this. This is why i’m getting salty about it. Many people already showed logs that clearly indicate the issue. But nothing is been done with them and it’s always thrown on the ā€œsorry but we can’t reproduce it at our officeā€ statement. That’s what makes me sick about it.
Also, quite funny how i decide to finally write a rant post and suddenly the COO responds instantly. I would love to see those kind of respond rates on your support department. They have been straight up ignoring me (even if i ask it very gently) for months.
Since only (some) are having issues, it doesn’t seem likely Pimax software or firmware. Same because it isn’t isolated to just Pimax headsets. Same as far as SVR goes.
Seems more like a difference in (some) chips, either in headsets or controllers.
The ICs suffered more than one issue in the left controller with the click and in some cases the ability to center correctly (I had the latter one and had to RMA). Perhaps a QA issue in one of the chips?
You do know that the og Vive has older Dongles built into the headset vs Vive pro/index/pimax and all of them would be affected then when using Index Controllers and are not.
However your post could be said to indicate that the issues could be as you said ā€œreflections, motherboard Usb etcā€¦ā€
Valve is in any event looking into this with Pimax. Also the fact many folks like @dogbite are not having these issues points that the problem is not consistent or all pimax headsets would be affected and they are not.
Now maybe if you live near a pimax user whom is not having Index Controller tracking issues. Bring your headset and controllers over to their house. You might find that it could be something in your system or something else.
Why Valve is also investigating. So no it is not just pimax headsets.
PimaxUSA likely responded due to my @ mention and being online so no not really a coincidence.
It seems you have missed @Leonardo’s posts that show it is not being ignored as well.
Now the question is, what kinds of games do you play? For example, in Pavlov my headset is completely fine. In Beat saber it’s all over the place.
For me it’s also only my left controller messing up. But it’s working perfectly when i use my Index or Left controller with USB dongle. That’s what makes me believe it’s 100% related to the headset or firmware.
@Heliosurge @anon57422158 Apologies for my heated response. It’s just that i bought this headset because i loved the idea sooo much, but it has given me nothing but a headache over the past year. And that just disappoints me. I want the product to be good, but for now it’s just a paperweight devalueing on my desk. And that makes me mad/sad.Especially when support is not there to help you with the issue. I would love to try a replacement headset for example. But i can’t even get a response. The only response i get is ā€œGo e-mail this guy (alex.liu@pimax.com)ā€ and on that e-mail address i never get a response.
Now Paul since I believe you said you LH v1.0 maybe try an experiment and try your index controllers with them as index controllers are compatible with both LH systems.
I did, it results in the exact same tracking issues. Even though the controllers are operating on LH1.0, it seems like they are still pushing more data than the wands do, thus causing them to fail tracking properly. Do note that my issue only exists on fast pace movements, i don’t have the controllers flying around all the time like others sometimes have here. They just get stuck for a few milliseconds in my case.
I’m surprised it’s game specific for you. I’d check the logs, you just may not notice it. I got to the end of HL:Alyx before realizing this is defo a pimax issue.
For me it is only my left controller, but I do get occasional oddities with the right controller. Also visible in the log. These are much more forgivable though.
Gonna have to agree though, this is a Pimax issue. Stop trying to say it effects all other headsets. It does not, plain and simple. I have THREE vr ready machines, all do the same thing with a pimax, NONE do it with a vive or index. I’ve done it in different houses too. It is absolutely 100% the hmd or software. Some of this might lie on valve to help - and I’m totally okay with the issue being a thing. I deal with EOL components all the time at work, and this stuff happens. It’s the response that’s just embarrassing. The customer ain’t wrong. This is the same response stuttering got for SIX MONTHS before finally it was acknowledged and fixed.
Your v1 LHes did you update the firmware as awhile ago a RoadtoVR Article said Valve needed to push an update out as Beatsaber users were moving faster than thought posdible.
Yes they are up to date.
