# Table of Contents (Wiki)
**URL:** <https://forum.openmr.com/t/table-of-contents-wiki/10851>\
**Category:** Guide Repository\
**Tags:** directory\
**Created:** [November 30, 2018, 9:09pm UTC](https://forum.openmr.com/t/table-of-contents-wiki/10851 "2018-11-30T21:09:52Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Davebobman](https://forum.openmr.com/user_avatar/forum.openmr.com/davebobman/32/3348_2.png) [@Davebobman](https://forum.openmr.com/u/Davebobman)\
**Post date:** [November 30, 2018, 9:09pm UTC](https://forum.openmr.com/t/table-of-contents-wiki/10851/1 "2018-11-30T21:09:52Z")
</div>
> **Basic rules for this wiki**
This is a wiki, which means ([almost](https://blog.discourse.org/2018/06/understanding-discourse-trust-levels/)) anyone can edit it. If you find a helpful or interesting link, please add it here.
1. If your post fits under an existing category, then put it there. If not, then add a new (somewhat broad) category.
2. Links only (not paragraphs). Use the hyperlink tool to give an appropriate name (ie solutions should list what is being fixed/ how to fix it) so that people can find what they are looking for.
3. When sharing a solution make sure that your link goes to the comment with the solution in it (if the OP contains the solution, then share that).
4. External links (non-Pimax/non-forum) should be labeled as [External].
5. Keep things clean (figuratively and visually). No one likes a messy post.
6. When sharing forum links, feel free to use user links (aka ending in ?u=YourUsername). It is fine to take credit for a good share.
> **General Forum Rules, Guidelines, and Tips**
1. [Official Code Of Conduct](https://forum.openmr.com/t/code-of-conduct/9973?u=heliosurge)
2. [Community Guidelines](https://forum.openmr.com/t/forum-rules-of-conduct/5173?u=heliosurge)
3. [Forum Tips / Tutorial category](https://forum.openmr.com/c/OMR-ANOUNCE/site-map/25)
> ## [Guide Repository](https://forum.openmr.com/c/Guidebank/73)
> [@About the Guide Repository category](https://forum.openmr.com/t/about-the-guide-repository-category/34365):
> Contains Useful Guides on Setup, Mods, Settings Guides & More! Tags: directory WiP will contains directiries of other Tag Contents here. pisetup PimaxVR setup guides piguide PimaxVR Mods related setup WiP Setup guides game-setting game settings & mods Contact [@Guide](https://forum.openmr.com/groups/guide) if interested in helping to create & curate guides.
[PimaxVR Setup Guides](https://forum.openmr.com/tags/c/Guidebank/73/pisetup)
- Hardware & Modules Setup
[PimaxVR Mods & Settings](https://forum.openmr.com/tags/c/Guidebank/73/piguide)
- Mods, Printables, Alternatives & setup
[Game Setting Guides](https://forum.openmr.com/tags/c/Guidebank/73/game-settings)
- Game settings & Mods
_ **Still a Work in Process** _
> **TroubleShooting Solutions**
### Featured
1. **[How To Make Your Pimax Image Crisp (Sharp) - by Teigue](https://forum.openmr.com/t/how-to-make-your-pimax-image-crisp/29688)** - (July 2020)
2. **[Program To Update SteamVR Settings - by BNP](https://forum.openmr.com/t/new-program-for-updating-steamvr-config-for-wide-fov-automagically/30144)** - (Aug 2020)
3. **[Improve MAS Audio Volume - by Fresco](https://forum.openmr.com/t/pics-overlooked-setting-found-increased-volume-dramatically-pimax-vision-8kx/29852)** - (July 2020)
4. **[Hand Tracking Module Setup](https://forum.openmr.com/t/hand-tracking-module-setup-guide/31560?u=heliosurge)** _Pimax Official Guide_ - (Sept 23, 2020)
5. **[DisplayPort and USB Extension cables for the 8KX (Tested) - by DrWilken](https://forum.openmr.com/t/8kx-extension-cable-options/32137)** - (October 10, 2020)
6. **[StudioForm MAS Counter Weights - by Davobkk](https://forum.openmr.com/t/new-8k-x-mas-counter-weights-available-now/31592?u=heliosurge)** - (Sept 26, 2020)
7. **[If the back of your MAS doesn’t go down far enough, then you can request a replacement hinge](https://forum.openmr.com/t/weekly-update-9th-september-2020/30754)**
8. **[The 8K-X should come with two face foams (one thick and one thin). If you are missing one, then you can request a replacement.](https://forum.openmr.com/t/weekly-update-9th-september-2020/30754)**
9. **[Fixed - SteamVR cuts off and on repeatedly - by Davebobman](https://forum.openmr.com/t/just-got-my-8kx-and-faulty-already/32314/9?u=davebobman)** - (October 15, 2020)
10. **[Getting Most out of Pimax HMD by neal\_white\_iii](https://forum.openmr.com/t/tips-for-getting-the-most-out-of-your-8kx/32487?u=neal_white_iii)** (Oct 21, 2020)
#### Software Solutions
> **Understanding IPD setup & Stereo Overlap**
> - [IPD & Stereo Overlap Setup - by Yen](https://forum.openmr.com/t/guide-how-to-achieve-perfect-real-view-with-pimax-ipd-compensation/18369?u=heliosurge)
> - [IPD and facepad thickness](https://forum.openmr.com/t/eyestrain-discussion-problems-and-solutions/16925/554?u=davebobman)
> **Basestation/lighthouse related**
> - [Lighthouse v1.0 setup Tips - by DrWilken](https://www.vive.com/us/support/vive/category_howto/tips-for-setting-up-the-base-stations.html)
> - [W10 Multiple Users - LH Tracking setup](https://forum.openmr.com/t/pitool-seem-to-not-support-multi-users-as-expected-with-suggestion-fix/18321?u=heliosurge)
> - [Headset Tracking Fix Mar 19/2019 - by DrWilken](https://forum.openmr.com/t/8k-5k-headset-not-tracked-workaround/17454?u=heliosurge)
> - [Headset not tracking due to basestation configuration](https://forum.openmr.com/t/new-pimax-8k-not-tracking/9497/35?u=davebobman)
> - [Disconnected or not tracking](https://forum.openmr.com/t/how-to-solve-disconnect-or-not-tracking-of-headset-base-station-controller-randomly-image-follow-head-although-not-use-base-station-pitool-91/11776?u=davebobman)
> - [How to Power Off Basestations remotely - v1 (outdated?)](https://forum.openmr.com/t/how-to-power-off-basestations-remotely/15205)
> - [How to Power Off Basestations remotely with your phone - works for v2](https://forum.openmr.com/t/8kx-lighthouse-2-0-standby/31602/18?u=davebobman)
> - [Basestation information](https://forum.openmr.com/t/v1-valve-lighthouses-identification-and-diagnostic/16330?u=davebobman)
> **Oculus Related Fixes**
> - [Pitool Fails To Launch Oculus Games (blocked by antivirus)](https://forum.openmr.com/t/resolved-oculus-games-wont-launch/18092/11?u=heliosurge)
> **Game Specific Fixes**
> - [Vector 36 - Weird haze/shadow in one eye only](https://forum.openmr.com/t/vector-36-graphics-glitch-one-eye-fixed-by-disabling-motion-blur-and-ambient-occlusion/18423)
> - [Dirt Rally VR - How to play without ReVive](https://forum.openmr.com/t/how-to-play-dirt-rally-vr-on-pimax-8k-5k-without-revive/18578?u=davebobman)
> - [Dirt Rally 2 VR - Optimal settings](https://forum.openmr.com/t/dirt-rally-2-0-optimal-settings/22214?u=davebobman)
> - [Project Cars - Play without Parallel Projections or SteamVR](https://forum.openmr.com/t/how-to-play-project-cars-on-pimax-8k-5k-without-parallel-projections-and-steamvr/18634?u=davebobman)
> - [Project Cars 2 - Play without Parallel Projections or SteamVR](https://forum.openmr.com/t/how-to-play-project-cars2-on-pimax-8k-5k-without-parallel-projections-and-steamvr/18644?u=davebobman)
> - [Half Life Alyx - Play without parallel projection](https://forum.openmr.com/t/how-to-get-rid-of-shadow-culling-in-half-life-alyx-without-parallel-projection/29727)
> - [Half Life Alyx - Play without parallel projection - alternative settings](https://forum.openmr.com/t/pimax-8kx-half-life-alyx-no-pp-large-fov-with-fog-really-amazing/32630)
> - [Dying Light VR - Play without Parallel Projections or SteamVR](https://forum.openmr.com/t/awesome-dying-light-vr-how-to-play-on-pimax-8k-5k-4k-without-revive-and-steamvr/18944?u=davebobman)
> - [Elite Dangerous - VR Startup Sequence](https://forum.openmr.com/t/ed-vr-startup-sequence-in-8k-world/6112?u=heliosurge)
> - [DCS - Mod to use zoom without parallel projections](https://forum.openmr.com/t/mod-to-use-dcs-zoom-without-pp/19573?u=davebobman)
> - [Buttery smooth DCS](https://forum.openmr.com/t/buttery-smooth-dcs-with-5k-xr-and-other-headsets/29035/4?u=davebobman)
> - [Assetto Corsa Competizione Settings](https://forum.openmr.com/t/assetto-corsa-competizione-settings-help/29042/17?u=davebobman)
> - [IL-2 Sturmovik mod fixes zoom issues without PP (for offline play only)](https://forum.openmr.com/t/pimax-and-il-2-sturmovik-parallel-projections/30821)
> **Solutions (+ misc info) for Technically Skilled / Power users**
> - [5K+ Distortion Profile Editing](https://forum.openmr.com/t/pimax-distortion-editing/11493?u=davebobman)
> - [Improve Windows performance by switching to the LTSC version](https://forum.openmr.com/t/a-note-about-the-perfomance-issues-on-this-forum/12357?u=davebobman)
> - [How the different FOV settings are represented in OpenVR](https://forum.openmr.com/t/all-the-different-fovs-of-pimax-5k/16053?u=davebobman)
> - [Pimax native projection and pre-lens warp transformation](https://forum.openmr.com/t/pimax-native-projection-and-pre-lens-warp-transformation/15775?u=davebobman)
> - [How the render target resolutions and the supersampling factors of Pimax and SteamVR work together](https://forum.openmr.com/t/how-the-render-target-resolutions-and-the-supersampling-factors-of-pimax-and-steamvr-work-together/19506?u=davebobman)
> - [HMDQ - a new tool for an OpenVR headset (and other hw) introspection](https://forum.openmr.com/t/hmdq-a-new-tool-for-an-openvr-headset-and-other-hw-introspection/21485?u=davebobman)
> - [HMD Geometry Database](https://forum.openmr.com/t/hmd-geometry-database-call-for-help/22074?u=davebobman)
> - [PiTool Open-Source](https://forum.openmr.com/t/building-pitool-github/22200?u=davebobman)
> - [PiTool IPD Offset](https://forum.openmr.com/t/pitool-ipd-offset-how-does-it-work/22344?u=davebobman)
> - [Unity developers: Easy “fix” for large/normal FOV without PP](https://forum.openmr.com/t/this-is-what-vr-game-developers-need-to-add-to-remove-clipping-culling-in-peripheral-view-on-pimax/26544?u=davebobman)
> - [PP HAM for 8K+ and 8K-X (by @risa2000)](https://forum.openmr.com/t/some-thoughts-on-the-new-pp-ham-on-pimax-8k-and-8k-x-headsets/29617?u=davebobman)
> - [I spent weeks diagnosing stutters on my 9950X3D + VR rig down to zero. Turned the whole thing into a free guide + one-click fix kit for dual-CCD X3D owners (by @Barz\_beast)](https://forum.openmr.com/t/i-spent-weeks-diagnosing-stutters-on-my-9950x3d-vr-rig-down-to-zero-turned-the-whole-thing-into-a-free-guide-one-click-fix-kit-for-dual-ccd-x3d-owners/43268?u=davebobman)
> **Miscellaneous**
> - [Multi-colored blinking power LED - stuck in DFU mode (use Sjefdeklerk’s Pimax Flasher)](https://forum.openmr.com/t/sjefdeklerks-pimax-flasher-4k-5k-8k/10231?u=davebobman)
> - [Multi-colored blinking power LED - Corrupted DFU Driver (if Sjefdeklerk’s Flasher doesn’t work)](https://forum.openmr.com/t/solved-led-keeps-flashing-red-green-blue/14441/31?u=heliosurge)
> - [How to change PiTool install location (+ PiTool v90 installer)](https://forum.openmr.com/t/pitool-1-0-1-90-installer-file-custom-location-instructions/9825?u=davebobman)
> - [OpenSSL Fatal Error (reported for PiTool v84)](https://forum.openmr.com/t/pimax-8k-user-since-yesterday-totally-desperate-with-open-ssl-fatal-error/9554/12?u=davebobman)
> - [How to restart Windows services](https://forum.openmr.com/t/is-piservice-part-of-pitool/14867/3?u=davebobman)
> - [PiPlay (not PiTool) settings cause 8K disconnecting issues](https://forum.openmr.com/t/8k-disconnected/11923?u=davebobman)
> - [NVidia Control Panel setting makes Unity apps unresponsive](https://forum.openmr.com/t/unresponsive-star-trek-bridge-crew/14095/11?u=davebobman)
> - [Audio not playing out of headset](https://forum.openmr.com/t/its-here-5k-yea-baby-yea-review-included/14564/29)
> - [How IPD works on the Pimax (due to canted displays)](https://forum.openmr.com/t/some-thoughts-on-the-ipd-discrepancy/14754)
> - [Everything is too dark in parts of a game (caused by HDR)](https://forum.openmr.com/t/list-of-the-game-ive-tried-last-night-that-work-didnt-work/15011/3)
> - [Non-English characters in Windows username cause SteamVR/Pimax issues](https://forum.openmr.com/t/pimax-5k-stuck-in-standby/14820/58)
> - [How to exceed the maximum resolution of 4096px imposed by SteamVR (solution in OP)](https://forum.openmr.com/t/how-to-exceed-the-maximum-resolution-of-4096px-imposed-by-steamvr/16067)
> - [Supersampling in PiTool/SteamVR (getting past 4096px limit)](https://forum.openmr.com/t/so-after-hours-of-tweaking-i-figured-out-the-best-and-easiest-way-of-supersampling-here-s-how/16197)
> - [NVidia anti-aliasing causes everything to look blurry](https://forum.openmr.com/t/5k-for-over-a-week-from-ok-to-wow/16144/6)
> - [How to get 5.1 audio working with Pimax](https://forum.openmr.com/t/trying-to-get-5-1-audio-working-with-my-pimax/16953)
> - [Mouse and game stutters caused by Windows 10 update KB4482887](https://forum.openmr.com/t/msoft-suggest-uninstalling-latest-win10-update/16905)
> - [Improve performance of Windows 10](https://forum.openmr.com/t/windows-10-updates-and-pitool-performance/21866)
> - [ASUS Aura software causes skipping/jumping/latency issues](https://forum.openmr.com/t/tracking-issue-latency-wobbling-effect-with-new-5k-xr/22410/5)
> - [SteamVR developer console (useful for changing setting and more)](https://forum.openmr.com/t/will-8kx-and-8k-continue-with-less-resolution-in-large-mode/24511/19)
> - [How to fix PiTool interface transparency issue](https://forum.openmr.com/t/about-the-way-to-fix-pitool-interface-transparency-issue/16179)
> - [SGSSAA antialiasing](https://forum.openmr.com/t/sgssaa-better-graphic-and-performance/26371)
> - [New SteamVR Update Disables Pimax Headsets](https://forum.openmr.com/t/new-steamvr-update-disables-pimax-headsets/26398)
> - [Update your DirectX games](https://forum.openmr.com/t/buttery-smooth-dcs-with-5k-xr-and-other-headsets/29035/4)
> - [Improve SteamVR Dashboard by changing gpuSpeedRenderTargetScale - part 1](https://forum.openmr.com/t/first-impressions-of-the-x-from-a-person-that-doesnt-care-about-color-and-doesnt-see-distortion-from-the-5k/29568/173)
> - [Improve SteamVR Dashboard by changing gpuSpeedRenderTargetScale - part 2](https://forum.openmr.com/t/first-impressions-of-the-x-from-a-person-that-doesnt-care-about-color-and-doesnt-see-distortion-from-the-5k/29568/182)
> - [How to close unresponsive apps](https://forum.openmr.com/t/would-it-be-possible-to-add-an-end-task-shortcut-into-vr/31725/2)
> - [Pitool Error Codes PDF 03/19](https://drive.google.com/file/d/13OWN7Mi4P0LcJQXZT4h46igFezTo2nQw/view?usp=drivesdk) - _Heliosurge Gdrive_ _Outdated needs updating_
#### Hardware/Other Solutions
> **Extension cables**
> - [Cable extensions](https://forum.openmr.com/t/pimax-5k-plus-usb-and-display-port-extensions-that-work-extra-power-adapters/18477/2)
> - [Cable extensions for 8K-X (confirmed to work by SweViver)](https://forum.openmr.com/t/100-working-3m-2m-extension-cables-for-pimax-8kx-native-4k-mode/25438)
> - [1m Mini-DP to DP extension/adapter for 8K-X (confirmed to work by SweViver)](https://forum.openmr.com/t/pimax-8kx-100-working-1m-extension-cable-for-laptops-mini-displayport/26025/3)
> **Miscellaneous**
> - [HMD not powered (caused by power supply failure)](https://forum.openmr.com/t/solved-bad-power-adapter-5k-down-after-3-4-hrs-of-elite/11184)
> - [Power LED flashing green](https://forum.openmr.com/t/miraculously-solved-5k-urgent-assistance-required/9720/12)
> - [Fix for issues on 4k crashing windows randomly](https://forum.openmr.com/t/fix-for-issues-on-4k-crashing-windows-randomly/16408)
> - [Applying a lens protector (also improves some visuals)](https://forum.openmr.com/t/im-gonna-call-my-tpu-experiment-a-success/11399)
> - [Fix Geometric Distortion aka “wobbling” (not edge distortion)](https://forum.openmr.com/t/distortion-fix-vertical-placement-on-face-is-paramount/11731)
> - [Lens frame not aligned properly](https://forum.openmr.com/t/psa-check-your-lens-frames-if-you-see-discrepance-between-eyes/11942)
> - [Frequent disconnects - solved with powered USB hub](https://forum.openmr.com/t/found-a-workaround-usb-problems-are-really-bad-now/12026)
> - [Frequent disconnects - caused by USB WiFi adapter](https://forum.openmr.com/t/pimax-8k-disconnects-every-5-seconds/18919/19)
> - [How to adjust your headset and IPD for the sharpest image](https://forum.openmr.com/t/how-i-calibrate-my-ipd-setting/12352)
> - [Another IPD configuration method](https://forum.openmr.com/t/pimax-ipd-image-method-0-1-don-t-use-far-ipd-need-near-ipd/14733)
> - [Headset not tracked because it was too close to basestations](https://forum.openmr.com/t/how-to-solve-disconnect-or-not-tracked-of-headset-base-station-controller-randomly-image-follow-head-although-not-use-base-station-pitool-91/11776/16)
> - [Flickering white dots caused by bad HMD cable](https://forum.openmr.com/t/replied-flicking-white-dots-5k/12148/59)
> - [Flickering white dots caused by bad grounding on PC accessories](https://forum.openmr.com/t/replied-flicking-white-dots-5k/12148/205)
> - [How to properly set basestation channels](https://forum.openmr.com/t/received-my-5k-today/16059/41)
> - [Finding the sweet spot](https://forum.openmr.com/t/improve-pimax-image/21551/3)
> - [One eye pixelated](https://forum.openmr.com/t/right-eye-pixelated-solved/29033/2)
> - [Company that replaces your housing with RE version (ruggedized, blue)](https://forum.openmr.com/t/re-housing-in-stock/29694)
> **Miscellaneous Headset Information**
- [Thermal Video of 8KX](https://forum.openmr.com/t/8kx-thermal-video/32284)
- [Thermal Video of 8K](https://forum.openmr.com/t/thermal-video-of-8k-and-misc-other-pictures/22682)
- [5K+ Teardown](https://forum.openmr.com/t/pimax-5k-teardown-panel-info/17276)
> **Games & Related Info**
> **Game Compilations**
> - [Pimax users: add games to this compatibility list(Created by aesopfabled)](https://forum.openmr.com/t/pimax-users-add-games-to-this-compatibility-list/13248/1)
> - [VR games for keyboard and mouse or gamepad](https://forum.openmr.com/t/vr-games-for-keyboard-and-mouse-or-gamepad/14050)
> **Skyrim**
> - [Fresco’s List (Over 100) Favorite Mods for SkyrimVR enjoyed in Pimax Vision 8kX](https://forum.openmr.com/t/frescos-list-over-100-favorite-mods-for-skyrimvr-enjoyed-in-pimax-vision-8kx/29855)
> ## Pimax Experience (PE)
> [Sequence start Bat/Scripts](https://forum.openmr.com/t/sequence-start-batch-scripts-dcs-world-elite-dangerous-etc-examples/34127)
> - By @mirage335 Dec 27, 2020
> **DCS World**
> [Pitool & Paraneters Spreadsheets](https://forum.openmr.com/t/certifying-pitool-version-latest-param-spreadsheets-for-dcs-world-and-elite-dangerous/34126)
> **Elite Dangerous (ED)**
> [Pitool & Parameters Spreadsheets](https://forum.openmr.com/t/certifying-pitool-version-latest-param-spreadsheets-for-dcs-world-and-elite-dangerous/34126)
> **6DOF Alternatives - No Lighthouses**
> [KinectToVR](https://youtu.be/6rKqCe0Mk-w)
> - **Youtube Video**
> - _Free_ Kinect VR Driver
> [Driver4VR](https://www.driver4vr.com/)
> - Low Cost easy configuration manager
> - Psmove (freepie)
> - Leap Motion
> - Kinect
> [NoloVR 4k 5k 8k](https://forum.openmr.ai/t/how-to-setup-nolo-vr-on-pimax-4k-5k-8k/18209?u=heliosurge) - By @park
> **Community & Other Info**
#### Pimax Headset Mods (excluding the Pimax 4K)
> **3D Printed**
> - [DAS adapters (by Dr.Cube)](https://forum.openmr.com/t/pimax-vive-das-3d-printed-adapter-parts/11500)
> - [Super DAS adapter (by @Yen)](https://forum.openmr.com/t/pimax-headband-v0-8/19746)
> - [PSVR Pimax Adapter(by @Virtualmisterl)](https://forum.openmr.com/t/pmvr-psvr-headstrap-with-pimax/17844/5)
> - [Narrow Face Gasket Spacer (by GrodenVR)](https://www.thingiverse.com/thing:3489564)
> - [Case Protector mod of Official](https://forum.openmr.com/t/backer-case-re-edited/17922/3) - by @cjselke
> - [3dprint In Toronto, Canada](https://forum.openmr.com/t/for-canadians-printed-part-for-vive-das/16937)
> - [SMAS 3dprint Sound Cups - by Virtualmisterl](https://forum.openmr.com/t/improved-pimax-smas-sound-with-a-3d-printable-headphone-sound-cup/31621)
> - [Comfort improvements for the 8KX (Blackout-Solution & prescription) - by Sightz](https://forum.openmr.com/t/my-own-comfort-improvements-for-the-8kx-blackout-solution-prescription/32881)
> **VR lens/glasses frame**
> - [VR lens/glasses frame](https://forum.openmr.com/t/im-not-really-the-first-one-prescription-resp-glasses-mount-3d-print-suggestion/19562)
> - [User Made VR Frames](https://forum.openmr.com/t/maybe-a-solution-for-prescription-lenses/18454/4)
> - [Prescription lens adapter](https://forum.openmr.com/t/pimax-5k-8k-prescription-lens-adapter/19796)
> **Face Cushion**
> - [Thicken Face Foam (Glasses)](https://forum.openmr.com/t/a-small-lifehack-for-pimax-glasses/17882)
> **Other Comfort Mods**
> - [Head strap cushion (by Davobkk)](https://forum.openmr.com/t/new-comfort-mods-for-pimax-head-strap-available-to-buy-now/13972)
> - [DAS mod for smaller heads](https://forum.openmr.com/t/5k-impressions-by-a-shortsighted-and-large-ipd-user/18453)
> - [My Pimax Comfort](https://forum.openmr.com/t/pimp-my-pimax-the-most-comfortable-headset-in-the-world/18012)
> - [3D printed fan](https://forum.openmr.com/t/anyone-interested-in-a-3d-printed-fan-kit/21546)
> - [DAS + Pimax basic strap combined (by g-coded)](https://forum.openmr.com/t/vive-das-pimax-cloth-strap/22673)
#### Community Group Channels
Discord Link (TBA)
Reddit Link (TBA)
FaceBook Link (TBA)
Steam Link (TBS)
[Contact for developers](https://forum.openmr.com/t/pimax-official-we-are-looking-for-the-cooperation-opportunity-with-vr-developers/17352)
#### Community Contributions and KS Specific Information
- [Pimax Backer Tracker Spreadsheet [External]](https://docs.google.com/spreadsheets/d/1sK1w_-gU6LaPYmZF1B-5W-Mr7gC1pFTuGkv2WBrQr-Y/edit#gid=598280210)
- [Compilation of issues with 5K+ and 8K](https://forum.openmr.com/t/compilation-of-issues-with-5k-and-8k/9738)
- [Pimax related photo gallery (aka MS Paint vs Photoshop)](https://forum.openmr.com/t/full-of-anticipation/6752)
- [This topic](https://forum.openmr.ai/t/table-of-contents-wiki/10851?u=davebobman)… [(inception noise)](https://inception.davepedu.com/)
- [https://forum.openmr.com/t/pimax-5k-8k-faq-updating/7462?u=davebobman](https://forum.openmr.com/t/pimax-5k-8k-faq-updating/7462)
- [PiTool, SteamVR, Application Resolution, spreadsheets. Project extendedInterface](https://forum.openmr.com/t/pitool-steamvr-application-resolution-spreadsheets-project-extendedinterface/25414)
**Post date:** [June 30, 2020, 9:28pm UTC](https://forum.openmr.com/t/table-of-contents-wiki/10851/5 "2020-06-30T21:28:58Z")
</div>
**Post date:** [July 13, 2020, 5:56pm UTC](https://forum.openmr.com/t/table-of-contents-wiki/10851/6 "2020-07-13T17:56:46Z")
</div>
**Post date:** [September 12, 2020, 2:44pm UTC](https://forum.openmr.com/t/table-of-contents-wiki/10851/7 "2020-09-12T14:44:05Z")
</div>
