Sword controller not working with Vive Pro 2
My Sword controllers work perfectly with my 5Kplus headset, but when I try to pair them with a Vive Pro 2 headset, the right Sword controller is not properly recognized in SteamVR. It tracks OK, but the buttons do not work. My right sword controller is much older than the left one, so maybe it’s a problem caused by old firmware. Since the controller works fine with the 5kplus, it’s probably not a hardware problem.
Anyway, does anybody have any idea how I might solve the problem?
PS: I contacted Pimax support about it, but they say they cannot help me.
Can you pair other lighthouse controllers like index or Vive Pro with your HTC headset?
Thank you for replying. I only have two Sword controllers, no other lighthouse controllers. The weird thing is, the left Sword controller works perfectly fine with my Vive Pro 2 headset. The right controller will pair and track, but in the SteamVR controller test it just shows a question mark, and the buttons do not work. As far as I know, the only difference is that the right controller is fairly old, it was one of the first to be shipped, whereas the left one is new, I bought it as a replacement last year. Here’s a couple of pictures from the controller test in SteamVR:
I’d recommend trying to buy or borrow a lighthouse controller, you can pickup Vive Pro really cheap in exchange stores.
It might be an issue with the 1 of 2 radios in your VP2 instead of an issue with the pimax controller itself.
There are 2 radios per headset to allow pairing of two controllers, these use 2.4ghz but are not Bluetooth but Nordic enhanced shock burst as used by all lighthouse tracked devices.
Alternatively if you have a SteamVR dongle (USB) you could try pairing the right controller to the dongle.
Ideally you want to determine if the headset is the problem instead of the pimax controller
Yes, that sounds like a good idea. No point in spending hours trying to sort out the problems, if I can get another controller for cheap.
Lighthouse options are great :+1:
