What Pimax considers ‘all run hot’ at let’s say perhaps 50C and what a few users notice at 55C from some headsets, may be a very significant difference in 8kX failure rates.
Inductors and capacitors tend to have mean-time-between failure rates that may drop off as sharply as 1 million hours at 45degC and 95% of rated voltage, down to 1000 hours at 50degC or 100% of rated voltage, down to only 100 hours at 55degC or 105% rated voltage. Nearing the limits of both ratings at the same time is liable to have an even more drastic effect.
What Pimax considers a reasonable failure rate, let’s say 1%, might be far below industry standards for a quality product, and thus, ‘shouldn’t worry’ may be good advice in the vast majority of cases. However, that doesn’t mean us taking some extra precautions is unwarranted. Manufacturing defects and mechanical breakdown of thermal paste happens. Consider that at even a 1% failure rate, 1 in 1000 of us will be unlucky enough to go through two warranty returns in a row.
Speaking for myself, I would rather know a lot more about the normal and outlier temperatures reported, so I can stick a heatsink on the thing before I risk being one of those 1 in 1000 unlucky folks. Such things have happened to me before.
Two warranty returns is a lot of downtime.
So, while I trust Pimax for reasonable quality going forward, overheating failure rates that are well below industry standards and acceptable to any company, still might be something I want more details about, and possibly to improve on.
Ideally, Pimax would have released a datasheet, like we would get for an operational amplifier chip from Texas Instruments, showing the statistical distribution of various temperature points from many headsets produced, with a few example thermal images included. This is a consumer product though, and Pimax is a small company as it is, so it is unlikely that much research will be done (probably not cost effective to do).
So, on the chance that you do have an unusually hot device, that data point is valuable to know. Thanks for investigating this.
_
@Finn No, a FLIR camera is far more accurate than any thermometer.
